Go to Post STEM blushes, and asks if Art would like to go out for a date. - Cothron Theiss [more]
Unread 27-01-2008, 17:07
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Team 1711 prototype
http://www.flickr.com/photos/23220170@N07/
Heres a few images of the robot design we've created. The "jaws" are pneumatically operated and grab the ball loading it to the arm. When the arm is raised the ball is parallel with the over pass and the upper jaw launches it over. We originally were going to use 2 tread wheels and 2 mechanums but then opted for all mechanum. Questions comments or suggestion are appreciated.
Unread 27-01-2008, 17:10
Jaybee1405
Posts: n/a
Re: Team 1711 prototype
looks awesome!
do you stay within the 80" rule?
Unread 27-01-2008, 17:24
ROAR.
FRC #1711 (RAPTORS)
we stretch out to 81 inches when the arm lifts up and is in possession of a ball. Luckily its the third week so we can adjust for that
Unread 27-01-2008, 17:28
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
very impressive
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 27-01-2008, 17:32
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Very clever design! I'd love to see a movie of it doing it's thing, it looks like it would be very fun to watch.
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Remember it's not 80" long it's fitting into a 80" circle.
BTW I love the design.
Unread 27-01-2008, 17:36
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
Team Role: Mechanical
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
we have a freakishly similar design....may i ask what material you used for the "jaw"....also how do you close it up to fit inside starting position.....congratulations on an amazing looking robot
here is our design (sadly we dont have anyone experienced with CAD) so we use chalk and a board...the design is to scale..we have a protoype, much like yours except with a different method of gripping the ball (we used PVC...i dont personally like the pvc idea i like yours much better)
Unread 27-01-2008, 17:37
Jaybee1405
Posts: n/a
No it's not. You may not have any two points more than 80" apart (horizontally).
Unread 27-01-2008, 17:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's neat! uses up a lot of air though, doesn't it? we are also dealing with air consumption issues
Unread 27-01-2008, 17:43
IndySam's Avatar
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that exceeds the size dimensions specified in Rule <R11>. While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright cylinder).
Read this http://www.chiefdelphi.com/forums/sh...&highlight=r16
Unread 27-01-2008, 17:45
MrForbes's Avatar
AKA: Jim
We've been thru the 80" rule discussion in a few different threads...and the Q&A addresses it also....the circle thing is an example, but the rule says only that you can't have two points further apart than 80" in a horizontal direction.
Measuring this can be a bit difficult.
Unread 27-01-2008, 17:47
AKA: Eitan
oh and can i reccomend you use the same tread that u used for the traction wheels as ball "grippers" they grab the ball like no other
Unread 27-01-2008, 17:48
Jaybee1405
Posts: n/a
I was told by an official FIRST regional inspector that it is not an upright cylinder. The shape is more like a very high piece of pie (ex. take an 80" long piece of extrusion and make a sweep from the farthest point.
Thank you Squirrel.
Unread 27-01-2008, 18:54
ROAR.
FRC #1711 (RAPTORS)
The Jaws are made from some AL pipes one of our mentors shop had lying around. As to fit in the starting dimensions the Jaws fold up against the arm almost vertically. Its just barely under height restriction and the 80in rule is a little touchy for us. Were gonna have to bend or shorten the jaws slightly
  #15   Spotlight this post!
Unread 27-01-2008, 21:06
ROAR.
FRC #1711 (RAPTORS)
We used 1" electrical conduit and a pipe bender. Also, if you use conduit, DO NOT DRILL THROUGH IT or flatten it. Use pipe clams to avoid creating potential failure points. Note: Last year at the Michigan regional a team constructed an arm out of PVC and it snapped.
Team 100's prototype spinmunky Robot Showcase 10 15-01-2007 12:56
Team 358 Shooter Prototype Xero0ne Robot Showcase 14 20-01-2006 21:03
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
