Go to Post Can you restate your observation in a manner that reconciles with physics? - Madison [more]
Unread 28-01-2008, 03:59
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
PSA: Banebots as replacement for FP motor
Being worried about breaking our FPs early with no spares, I looked into the motors that came with our 64:1 gearboxes some more. The same 550 that came in the kit. They are not an exact match, but are very similar to the FP in terms of performance.
For now, we will run our arm with two 550s and swap for FPs later.
So, at a regional and need to replace a burned out FP? A 550 will do the trick. you could even run a 550 paired with a FP (not the best match, but it will do) in a pinch to replace a dual FP setup.
With the lack of FP spares readily available, this could save a lot of teams in a pinch. I know I'll make 973 bring all our 550 (we have 5-6) motors to our regionals for teams to use.
Unread 28-01-2008, 07:28
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: PSA: Banebots as replacement for FP motor
I like all of your reasoning and especially your GP offer for spares. I don't want any teams who read this note to get the impression that you can use two BB 550 motors on their robot. The KOP only included a single BB 550 motor The second BB motor is the 540. So as you suggest, the BB 550 might be able to substitute for a FP motor that breaks in competition and only if you are not already using it on your robot for another mechanism.
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 28-01-2008, 12:15
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Hey, Adam, don't forget the Spare Parts booth! They should have FPs, gearboxes and all. (And how long does it take to remove an FP from its gearbox?)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 28-01-2008, 13:30
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
if I remember correctly I read somewhere I think the most recent team updaelte said ifi will stock FPs soon. I'm on my phone so I can't check but I'll look as soon as I can.
I just checked team update 5 and it says first is working with FP to get some spares at IFI
Unread 28-01-2008, 18:44
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
You're only allowed to use a single Banebots RS550. Only one is provided - and it isn't in the list of additionally allowed motors.
Unread 28-01-2008, 19:04
AdamHeard's Avatar
Lead Mentor
Yes, I'm well aware of that. I think a majority of teams will not be using two FPs and a 550. this is to help the teams in that situation.
If are are referring to 973 running two 550's for now, that is to keep our FPs nice and new; we won't run during the season like that.
Unread 29-01-2008, 13:48
Andy L's Avatar
FRC #1458
Still pointing to Team Update 5 IFI should be selling FPs within the week
Banebots/Cim motor programming question Japper Programming 4 14-02-2007 12:02
Fisher Price Motor Replacement Gearbox Joe Johnson Motors 17 05-01-2007 07:35
Help! Need replacement Fisher-Price Motor/Gearbox Mr. Van Motors 2 13-02-2003 07:35
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
Drill motor shaft replacement archiver 2000 1 23-06-2002 22:42
