End of the Match
At the end of the match, how do you release the air out of the pneumatic system?
Is it through programing or is it done mechanically? |
Re: End of the Match
i would think by urself by the release valve.
Open the valve manually.
According to rules, at the end of the match before the teams go out and pick up their robots, the refs must be able to open the pneumatic devices with ease. Therefore, you must have to release the pressure outside of the arena, without touching the actual bot. Am I correct?
Just to verify. |
a release valve was provide just for that purpose. it is dont manually
please speak english.
The Refs can use the manual release valve too, if necessary.
Just mark it's location well, so it's obvious where it is. The only related rules I found were: Quote:
#10
<G45> Arena Reset - ROBOTS must be designed to permit the release and removal of any TRACKBALLS from the ROBOT without being powered up after a MATCH. If a ROBOT violates this rule, the offending TEAM will be warned and requested to modify the ROBOT. If the modification is not made, the ROBOT may not be permitted to compete in future MATCHES. |
#11
| end of match autonomous mode | !aaaaa! | Programming | 23 | 15-12-2007 14:47 |
| End of match ramp-bot question... | AHS1599 | Rules/Strategy | 1 | 18-02-2007 12:34 |
| pic: End of final match | Ken Platteschor | Extra Discussion | 1 | 19-06-2005 19:01 |
| End of match tethering | DirtyBird213 | Rules/Strategy | 2 | 15-01-2004 20:29 |
| End of Match Score | SkitzoSmurf | Rules/Strategy | 1 | 10-01-2004 14:02 |
