Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 28-01-2008, 15:43
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
Rookie Year: 2007
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Still don't understand how to wire IR?
I dont understand where the ground from to the digital io's come from.
I noticed that John C said that the two black wires in his picture go to the terminal block but don't we see that they are connected to the terminal block?
There is a pic in this post where it's all visible except the power distribution block.
The two white wires in the zip tie go to 12v from the battery. The two black wires in the zip tie go to ground on the terminal block.
http://www.chiefdelphi.com/forums/sh...12&postcount=4
So where does the ground to digital i/o come from?
I also don't understand why we need to use all four positive/ground pins? I got the board to power up using a 7.2V backup battery where the positive is connected to pin #1 and ground is connected to pin #3 and had it learn some buttons, so I don't see why it is necessary to use all four pins.
Thanks for the
Unread 28-01-2008, 22:45
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Still don't understand how to wire IR?
We too had some issues with using the Digital IO for the IR PCB. The Digital IO lines have pull up resistors internal to the Robot controller. They will always look like a '1' to your code, unless a signal can pull them down.
We chose to use the Analog inputs for the IR outputs. This way we trigger on a '1' signal and are not looking for the Digital pins to go low. Choose a value somewhere between 0 and 1023 for a triggered value. The IR PCB puts out a 100ms pulse. between 0 and 5V. The grounding through IR pins 3 and 4 should be sufficient.
We strongly recommend using the 12V supplied from a fuse panel to power the IR PCB. Using 7.2V from a PWM output will drain your backup battery. The backup battery is the sole source of power for your RC communications between the Robot and the Operator interface. Unless you intend to build the on-board charging circuit, you may have spotty IR links late in in the match.
Hope this helps.
Team MARS = 1.523 AU from the SUN!
Jim E.
How long to understand camera and write useful code RGuindon Programming 3 16-12-2007 01:37
Pinning? Apparently I just don't seem to understand Brindza Rules/Strategy 61 14-03-2006 21:30
How to wire a 40 Amp Breaker? dez250 Electrical 6 09-09-2003 11:17
Shelf and board dimensions still don't add up kmcclary Off-Season Events 12 20-10-2001 09:12
