I am using a switch function with MPLAB within the autonomous section fo user_routines_fast.c and the code I've written up does not seem to be executing...ever. For example, when I load the attached code, the motors attached to the PWM outputs only turn for 3-4 seconds and stop. I asked another team about it and their response was that the delay right above the while loop was the reason. I changed the value to 570 and the results were the same.
Do you think the numbers next to the "#define" section are the issue or does MPLAB hate us and the switch function alltogether? Any and all help is appreciated! Thanks in advance, Team 2348. Last edited by darkdwarven : 28-01-2008 at 19:52. Reason: The smiley did not match with the title |
Re: Switch Function Problems
Code:
static unsigned char delay; static unsigned char direction; static unsigned char time; |
Thanks!
It works perfectly now. Next thing to do, figure out where we went wrong with IR sensors and I'm sure there is a thread out there with the information I need. |
| printf, call of function without prototype problems | cprogrammer | Programming | 3 | 11-05-2006 18:21 |
| problems programming knob and switch | caderader | Programming | 4 | 16-02-2006 16:45 |
| Need Help Wiring Micro Switch/Limiting Switch | Windward | Electrical | 2 | 07-02-2006 18:26 |
| Labview problems and code problems | ajsetter | Programming | 25 | 18-01-2006 17:07 |
| Problems programming a switch | caderader | Programming | 2 | 18-02-2005 22:06 |
