Go to Post There are so many creative and brilliant minds out there that build wonderful inventions and machines---surely we can be equally creative and open minded ... - Tonya Scott 476 [more]
Unread 28-01-2008, 20:59
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Question PORTB Help
I was looking through Kevin's Encoder program and noticed that in order to use the extra encoders, Kevin had to use the bundled interrupts. In order to distinguish between the interrupts, Kevin used PORTB to see which of the 4 fired. I was wondering what the PORTB extacly is, and how can I implement this myself.
Thanks Stephen
else if (INTCONbits.RBIF && INTCONbits.RBIE) // encoder 3-6 interrupt?
Port_B = PORTB; // remove the "mismatch condition" by reading port b
INTCONbits.RBIF = 0; // clear the interrupt flag
Port_B_Delta = Port_B ^ Old_Port_B; // determine which bits have changed
Old_Port_B = Port_B; // save a copy of port b for next time around
if(Port_B_Delta & 0x10) // did external interrupt 3 change state?
#ifdef ENABLE_ENCODER_3
Encoder_3_Int_Handler(Port_B & 0x10 ? 1 : 0); // call the encoder 3 interrupt handler (in encoder.c)
#endif
if(Port_B_Delta & 0x20) // did external interrupt 4 change state?
#ifdef ENABLE_ENCODER_4
Encoder_4_Int_Handler(Port_B & 0x20 ? 1 : 0); // call the encoder 4 interrupt handler (in encoder.c)
#endif
if(Port_B_Delta & 0x40) // did external interrupt 5 change state?
#ifdef ENABLE_ENCODER_5
Encoder_5_Int_Handler(Port_B & 0x40 ? 1 : 0); // call the encoder 5 interrupt handler (in encoder.c)
#endif
if(Port_B_Delta & 0x80) // did external interrupt 6 change state?
#ifdef ENABLE_ENCODER_6
Encoder_6_Int_Handler(Port_B & 0x80 ? 1 : 0); // call the encoder 6 interrupt handler (in encoder.c)
#endif
Unread 28-01-2008, 22:03
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: PORTB Help
dont worry about it. FYI though, it's an I/O port on the microcontroller. (i know this cuz i'm trying to learn the PIC). for more info, look to the pic18f8722 data sheet, but try to avoid going into the chip architechture oif at all possible, unless you really want to.
Unread 28-01-2008, 23:00
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: PORTB Help
PORTB is a register value for each of (1-7)? digital_io. It says what each bit is in the datasheet, I would suggest taking a look at that.
basically
Code:
that line uses the XOR to compare the new value to the old one. so if you have 10010101 as your old one and 10000101 as your new one the "Port_B_Delta" will be 00010000 which is also = 0x10 in hex and = 16 in our regular number system.
which is where this comes into play:
Code:
or something like that...
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
