Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 28-01-2008, 21:52
sfs sfs is offline
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
Use of PWM outputs 13-16 via WPILib
Has anyone successfully used PWM outputs 13-16 in WPILib? We have not yet needed them, but I wondered if the SetPWM() function does what is necessary internally to allow them to be used in the same manner as ports 1-12. I ask because the default code requires the use of the Generate_Pwms() function when using ports 13-16.
Unread 29-01-2008, 09:47
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Use of PWM outputs 13-16 via WPILib
WPILib only drives PWM ports 1-12 directly since those are the ones controlled by the master processor. You can control the other servos using some clever code that Kevin Watson wrote.
There is an explanation of how to do it in easyC here. Even though you are not using easyC, it is based on WPILib and the code works the same way.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Problem with PWM outputs on RC Adam Richards Control System 1 20-02-2007 06:37
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
