Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 29-01-2008, 01:00
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Coupling a Globe Motor
How would I couple a globe motor to a sprocket, pulley or gear??
pictures would be nice
Thanks in advance
Unread 29-01-2008, 01:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Coupling a Globe Motor
This looks like a relatively easy way
http://andymark.biz/am-0159.html
Unread 29-01-2008, 08:26
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
The globe motor gearbox has a 3/8" diameter shaft, and is fairly long. We have coupled to it two ways.
1) Find a gear with a 3/8" bore, drill and pin the gear to the shaft.
2) The shaft is supported by a single bronze bushing, so it doesn't like large cantilevered loads. We have used a shaft coupling to connect it to second, co-axial shaft, which was either keyed or had a gear pinned to it.
3) The AM adapter (linked to above) looks pretty nice as well.
Bengineer
Nippon-Denson Motor Coupling needed Stephen P Motors 2 07-09-2005 22:52
Gear Coupling for Jideco Window Motor hayakuneko Motors 4 30-01-2005 18:35
Globe Motor Coupling MechaJag Motors 5 24-01-2004 18:12
Motor coupling archiver 2001 19 23-06-2002 23:35
Help! Need Motor Coupling FAST! Eric Reed General Forum 3 06-09-2001 00:40
