Go to Post Whatever you do, make it idiot-proof. Not because your drivers are idiots, but because the fewer precision maneuvers they have to do, the more awesome driving (and scoring!) they have time to do. - Ian Curtis [more]
Unread 29-01-2008, 01:41
jwkelly jwkelly is offline
AKA: Mr. Kelly
FRC #0585 (CyberPenguins)
jwkelly is on a distinguished road
New post-compile patch program for C18 HEX code . . .
All -- Team 585 has created a patch program in PERL that allows you to patch the compiled hex code with constants defined in an external file (i.e., constants not initialized at compile time). The upshot is that you can make a single build of the controller software, but maintain the flexibility of changing constants (e.g., calibration curves) as tuning and hardware changes dictate. Simply put, manage one controller build and a few text files of constants rather than several special builds that each have different constants defined in their source code.
I have enclosed the program but had to change the name from patchy.pl to patchy.txt to support the upload file types.
Please let me know if you find utility in this . . . um . . . utility.
Cheers-
jwk
New C18 3.0+ Compatible FRC Code Kevin Watson Programming 441 27-03-2008 15:30
MPLAB/c18 not creating a .hex file Cheezmeister Programming 7 15-02-2007 15:01
Hex code loader for the robot! paulcd2000 Programming 4 22-10-2006 01:58
New MS Patch.. very important. devicenull IT / Communications 0 05-01-2006 18:19
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
