Go to Post The mission of FIRST is not just to promote science and technology, but to help every student involved to reach their full potential and achieve their dreams - Mike Ciance [more]
Unread 29-01-2008, 08:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Simple question regarding OI LED's
One of my programmers was playing with the LED's on the OI board, but was curious.
He put the statement Pwm1_red=1; in the default routine, and the Led did not light up red. I was at a loss as to why it didn't work. So, what's up with this?
Unread 29-01-2008, 09:17
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Rookie Year: 2007
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Re: Simple question regarding OI LED's
That should work...
If this is happening every loop, either the light is being turned back off or the light doesn't work.
Make sure that no other code after that points turns the light back off, and try turning on all the other lights.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 29-01-2008, 09:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The OI feedback LEDs share data space with the user display byte. You can't use them both at the same time. If the OI is showing the user byte, none of the LEDs will light.
Unread 29-01-2008, 12:03
Tom Line's Avatar
Rookie Year: 1999
Aha! That would make sense. It stopped working after we added some code that prints the PMW values of our choice out to the user byte for debug. Thank you!
EasyC Question regarding simple program aeasson Programming 6 14-01-2008 23:16
Simple question on MPLabs itsme Programming 7 20-01-2007 00:05
Quick Simple Question ImmortalAres Programming 8 17-06-2005 13:08
simple joystick question vexingspector Programming 5 19-02-2005 18:55
simple question... answer it archiver 2001 1 24-06-2002 01:02
