Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 29-01-2008, 11:37
Sparticusrobo08's Avatar
Sparticusrobo08 Sparticusrobo08 is offline
FRC #2341
Sparticusrobo08 is an unknown quantity at this point
Thumbs down Easy C problem
I did like the instructions said for the initial setup for easyC but when i went to download the On-line Window to download the On-line code a window popped up and said that the Program light should be orange and the serial cable should be connected all of this was done so where did I go wrong? And what should i do to fix it?
Unread 29-01-2008, 23:23
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Easy C problem
Are you using the right COM port number?
Unread 29-01-2008, 23:53
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Re: Easy C problem
Did you press the PROG button on the controller until 2 of the 5 lights went orange?
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 30-01-2008, 08:19
BanksKid's Avatar
BanksKid BanksKid is offline
..as The Circuitrunner.
AKA: Banks, Ethan Banks
FRC #1002 (Circuitrunners)
BanksKid will become famous soon enoughBanksKid will become famous soon enough
Send a message via AIM to BanksKid
Re: Easy C problem
well there's your problem your using Easy C. but seriously you might consider calling intellitech if they'r still the ones who make it.
"WE HAVE A CAMERA RIGHT NOW!"
R.I.P. SAM
Problem with easy C CameraTracking function mjveld1018 Programming 9 16-02-2007 19:36
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Easy-c MC_FALCON_842 Programming 11 13-10-2006 22:42
Easy C, loader problem gabrielse Programming 13 02-02-2006 07:44
