Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 29-01-2008, 11:49
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
Best Sprockets
at this point the only way i can see our arm powered is if I use the keyang motor with a small sprocket and a large sprocket attached to the pivot of our arm. I wanted to do a winch with a lever but that seems to be out because of the 80 inch envelope. If there are any other suggestions they would be greatly appreciated. The big question is where should I get the sprockets?
Andymark has some and so does IFI. our team hasn't done anything with chain in years, so i am making it up as i go along...
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Who's the best vendors for getting 25 chain and sprockets? waialua359 Kit & Additional Hardware 5 08-01-2008 22:17
sprockets Adama Technical Discussion 12 14-01-2007 14:05
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
sprockets Greg Needel Technical Discussion 0 23-04-2002 12:30
