Go to Post I actually see no issue about the sentence, but then im still in college and only half way edumacated, i am only eduma right now. - Alex Cormier [more]
Unread 29-01-2008, 11:56
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
double solenoid diodes?
In past years, it has been standard procedure to wire two diodes into the double solenoids, thus allowing control of both sides of the solenoid with a single spike relay. I was explaining this to someone recently, and wanted to find the documentation on it, but was unable to find it, at first. After some searching, I was able to find this information in the "Tips and Good Practices" manual...from 2006. It is NOT in the corresponding manual for 2007 or 2008.
Is this procedure still necessary? If not, why not? (Have they changed the solenoids to handle back current?) If it is, why has it been removed from the "Tips and Good Practices" manual?
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 29-01-2008, 12:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: double solenoid diodes?
The SMC solenoid valves seem to have built in diodes, we used them on our Promobot we built over the summer/fall and wired both ends with reversed polarity to one spike, and it switches as it should.
By reversed polarity, I mean that you connect the red wire from valve end A and the black wire from valve end B to one spike output terminal, and the black wire from A and red wire from B to the other spike output terminal.
Unread 29-01-2008, 13:52
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
External diodes haven't been necessary for several years.
See the Spike guide from 2005: http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
Unread 30-01-2008, 16:50
kham's Avatar
kham kham is offline
K. Ham
FRC #2819
Team Role: Mechanical
kham is an unknown quantity at this point
Here's what you're looking for http://www2.usfirst.org/2004comp/5-T...evA-markup.pdf. See page 16. I just wired it, and it works perfectly. Why they no longer publish this diagram in the manuals is beyond me.
Double Solenoid Help doyler Programming 4 19-02-2005 11:36
Double Solenoid Wiring blindguyinanorg Pneumatics 7 09-10-2004 23:55
Double Solenoid Leak Darksun Pneumatics 4 18-02-2004 22:52
Double Solenoid Wires Lord Nerdlinger Pneumatics 4 17-02-2004 19:54
double solenoid gail OCCRA 0 11-10-2002 19:42
