Go to Post No matter their age, no matter their generation, every mentor and student must be responsible for their actions, and for understand that compromise and maturity are the paths to team success. - Eugenia Gabrielov [more]
  #16   Spotlight this post!
Unread 29-01-2008, 15:12
matt91 matt91 is offline
FRC #1779 (G-F.O.R.C.E.)
Team Role: Leadership
Rookie Year: 2007
matt91 is an unknown quantity at this point
Send a message via AIM to matt91
Re: Serious Problem of Unknown Origin
Ok well in that case what I would do is run the programing, and test your voltage everywhere in between the IFI board and the power source and the motors. Maybe the trouble is in the motors... have you driven the robot yet? Maybe there burned out?
  #17   Spotlight this post!
Unread 29-01-2008, 15:53
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
In addition to what everyone else has been saying (charge your battery or swap it out for a freshly charged battery), your OI should report battery voltage > 12.4 volts for a nice happy robot. Once you get there, make sure your Victors are calibrated. Neutral is orange, max in one direction should produce a green led (at the Victor), max in the other direction should produce a red led (at the Victor).
  #18   Spotlight this post!
Unread 01-02-2008, 10:08
Team865 Team865 is offline
FRC #0865
Team865 is an unknown quantity at this point
Thank you for your suggestions so far.
Currently we are charging one of our 'big greys' and will see what happens when we try again with it.
  #19   Spotlight this post!
Unread 01-02-2008, 10:30
FRC #0865
We've just tested our robot with a new battery, and the problem is resolved! The motors are now spinning at their normal speed. Thank you everybody for your prompt replies and "gracious professionalism".
  #20   Spotlight this post!
Unread 01-02-2008, 10:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm glad to be of help!
Do you understand why the robot behaved as it did when the battery was discharged? It might take some thinking to figure this out, but if you develop an understanding of how batteries work, specifically how the available voltage changes with charge state and current load, it should make sense.
  #21   Spotlight this post!
Unread 01-02-2008, 10:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Do not ever set your battery on concrete.
I don't understand the chemistry/physics behind it, nor do I ever intend to delve into the science of why it happens but something about rebarb, concrete and long half-life radiation drains your battery if it's in close proximity to concrete. I saw it happen repeatedly at the VA State Fair with our robot and rather than trying to understand why I'll just accept the fact that it happens for now.
What we saw was that the charger would say our battery was fully charged. We'd then transfer the battery to the robot and place it on the field. At the start of the match, the bot would move extremely slowly, and the OI would indicated ~7V on the battery. About 15 seconds into the match, the voltage would go UP and the robot would act normally. Who knows why ? What I do know is, we do not place batteries on concrete any more and we haven't seen the problem since.
If you thought your batteries were charged and then you get these results, perhaps this is why.
GitHub
  #22   Spotlight this post!
Unread 01-02-2008, 11:11
MrForbes's Avatar
AKA: Jim
The battery on concrete thing likely has to do with temperature, since colder temperatures slow down the chemical reaction that releases electricity (that's my incomplete understanding of it)
  #23   Spotlight this post!
Unread 01-02-2008, 11:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I'm highly skeptical of this. In olden times before plastic cases for batteries, this was true as slightly porous casing materials could would become moist on a damp concrete floor and let some current flow, draining the battery, but those days are a rather long way behind us. There simply isn't any possible way for batteries to self-discharge faster than normal just because they're on the floor.
If your robot was moving slowly for the first 15 seconds of a match, I think it's much much more likely that there was a programming error in your autonomous mode that was causing some of your motors to fight each other and put a large load on the battery. Autonomous mode IS 15 seconds long, after all.
  #24   Spotlight this post!
Unread 01-02-2008, 11:20
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
From my limited understanding of Physics and Chemistry, concrete should not affect the charge of the batteries in any way. It doesn't seem logical. Squirrel is probably correct about the temp, but the building at the VA fair is more likely hot than cold.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
  #25   Spotlight this post!
Unread 01-02-2008, 11:32
Rookie Year: 1998
Temp has some affect on batteries, but I don't think it's THAT great. I've got a panasonic SLA spec sheet pulled up that indicates you'd lose less than 20% capacity between 30C and 0C. Since as far as I know, all Regionals are held indoors or at least somewhere comfortably above freezing, I don't think you'd be likely to lose even that much capacity.
  #26   Spotlight this post!
Unread 01-02-2008, 14:13
JesseK's Avatar
FRC #1885 (ILITE)
No, it was 15 seconds of teleoperated period (sorry for being unclear) and we'd literally see the OI Voltage Indictor go from 7 on up to 9, then trickle up to 12.
It was wierd and unexplicable by everyone except our team lead, who said it was because we placed the batteries on concrete. We stopped putting the batteries on the ground, and the wierdness stopped happening. Who knows.
GitHub
  #27   Spotlight this post!
Unread 01-02-2008, 15:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Jessie,
This more likely from a dirty contact on the battery than anything else. There is no explanation other than extreme low temperature for the battery voltage rising during play. It is also possible that there was some veryhigh friction in the drive train that worked itself out during the match. Loose hardware is a good example. If one of the motors is running near stall the terminal voltage on the battery will read low. The battery internal impedance is .011 ohms. Using Ohm's Law and fudging a current draw of 200 amps you would expect to see 2.2 volts dropped just across the battery. However, the RC stops functioning when that battery voltage falls below 8 volts, so I think the 7 volt display you saw was in error.
The battery on concrete was an issue long ago with car batteries and the case material and the fact that the battery was not sealed. Sneak paths through leaking electrolyte, minute caracks in the case and the concrete would serve to discharge a battery left in contact with the floor. A simple insulator like carboard usually prevented the discharge, which took several weeks. Our battery does not suffer from any of these issues. In fact most modern batteries have no problem sitting on concrete or steel for that matter.
Al
WB9UVJ
www.wildstang.org
________________________
Unknown Device ID(0) DavidGitz Control System 13 28-01-2008 20:28
SERIOUS COMPRESSOR PROBLEM simeon1770 Pneumatics 6 18-02-2007 21:07
FIRST Unknown irishninja General Forum 4 24-04-2006 08:45
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
