Go to Post It is much harder for someone to misuse the labor you do than it is for them to misuse of the dollar you pledge... - IKE [more]
Unread 29-01-2008, 17:50
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Bearing Blocks
Our team is using the Andy Mark Supershifters with the 2'' longer shafts. Where would be a good place to buy bearing blocks for them? Or is it better to make our own?
Unread 29-01-2008, 21:11
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Bearing Blocks
You can buy pillow blocks (bearing blocks) with bearings in them from mcmaster-carr. (www.mcmaster.com)
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2008, 21:17
x7shaddow's Avatar
x7shaddow x7shaddow is offline
master of sleep
FRC #1346
Team Role: Mechanical
x7shaddow is an unknown quantity at this point
Re: Bearing Blocks
we ended up making bearing blocks for our mechanum drive last year, and they turned out good, but unless you have people who are good at welding and machining you might want to consider buying some.
Unread 29-01-2008, 21:50
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Bearing Blocks
we got some amazing plastic ones from mcmaster for about the same cost as metal ones but the weight like 5oz each and this is for 3/4" shaft
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 29-01-2008, 22:30
Team Role: Driver
Re: Bearing Blocks
Thank you all the help. We ordered some from McMaster-Carr.
Power Distribution Blocks, buying? 1596guy Kit & Additional Hardware 9 22-02-2007 18:21
Terminal Blocks in Kit of Parts? Mark Pierce Electrical 13 24-01-2007 00:37
pic: Shaft Drive Bearing Blocks MAteo9944 Extra Discussion 25 01-01-2007 11:22
[OCCRA]: Pillow Blocks? Fizzix OCCRA Q&A 1 12-10-2004 20:57
pillow blocks Jacqui Sutton Kit & Additional Hardware 1 11-01-2003 10:43
