Go to Post If 100 people from ChiefDelphi all wrote one full article on something that they are an 'expert' in, FIRSTwiki would be even better. - artdutra04 [more]
Unread 29-01-2008, 18:27
CarpeNoctem's Avatar
CarpeNoctem CarpeNoctem is offline
Ranger
FRC #1057 (Blue Knights)
Team Role: Scout
CarpeNoctem is an unknown quantity at this point
Exclamation Taigene Window Motor- Circut breaker
What is the circut breaker amperage require by FIRST?
Is it 20, 30 or 40?
When designing something completely fool-proof, we often underestimate the ingenuity of complete fools!
-Douglas Adams
Unread 29-01-2008, 18:38
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Taigene Window Motor- Circut breaker
Is it 20, 30 or 40?
See <R55>. It depends on what you use to regulate its motion. Otherwise, figure out which one will protect the motor the best while still allowing power.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 30-01-2008, 19:13
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Circuit breakers are chosen for the wiring used to feed a motor. A 40 amp breaker is used for #12 or larger wire. A 30 for #14 or larger and a 20amp for #18 or larger. Since the van door motor has a stall current of 40 amps you will likely be designing for much less run current (you don't want to stall the motor do you?). A #14 wire and a 30 amp breaker should be sufficient.
Al
WB9UVJ
www.wildstang.org
________________________
Please help.....Taigene window motors team 2191 Motors 17 12-02-2008 16:18
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
Taigene Window Motor Specs master_nickz General Forum 0 22-01-2008 15:53
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
