Go to Post Now there is something I am going to suggest to my team...."testing before ship (bag)"....on second thought, maybe I'll just ref! - ExTexan [more]
Unread 29-01-2008, 19:21
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
Rookie Year: 2007
penguain is an unknown quantity at this point
Changeing the Channel
I was wondering how to change the channel on one of the Robot controllers. so we can drive both of our robots at the same time
Thanks in Advanced
Barry Preston
STAG Robotics
Team #1997
Programming and Communications Officer
2007 Greater Kansas City Regional Champions
2008 Greater Kansas City Regional Finalists
Unread 29-01-2008, 19:32
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Changeing the Channel
Change the team number on the OI for the second robot, then power up tethered to pass the change on to the robot.
Unread 29-01-2008, 21:28
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
On the 2005 and later systems, the team number has to be set greater than 2048 in order to enable alternate channels. In your case, it might be most convenient just to flip the leftmost switch on the OI and use team number 3045 for the other (older?) robot. You will have to use the tether cable in order to get the number transferred to the robot.
Once you have the team number changed, use the channel select switches to choose the other channel. Here's the key:
Code:
1  2   3   4  Channel
X  ON  ON  ON  04
X  ON  ON OFF  13
X  ON OFF  ON  22
X  ON OFF OFF  31
X OFF  ON  ON  40
X OFF  ON OFF  01
X OFF OFF  ON  40
X OFF OFF OFF  40
A couple of weeks ago, we had no fewer than four of our robots running around simultaneously, all on separate channels.
Unread 29-01-2008, 21:40
AKA: Barry Preston
Rookie Year: 2007
thanks i'll try this out tomorrow
THANKS!!!
Barry Preston
STAG Robotics
Team #1997
Unread 30-01-2008, 19:47
AKA: Barry Preston
Rookie Year: 2007
Thanks...
Does this mean that you can't use more than 6 robotics on RF at a time
Barry Preston
STAG Robotics
Team #1997
Unread 30-01-2008, 22:47
Software Architect
That's correct: you can't have more than six simultaneous robots under radio control. However, FIRST can have up to 40, using an undocumented protocol. Unless you find a way to properly simulate the field control communication through the competition port connector, you won't be able to access the other 34 radio channels.
Unread 31-01-2008, 00:08
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Technically, you could change team numbers to have more than six robots working at a time, correct?
Unread 31-01-2008, 11:00
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
You'd need different team numbers unless you wanted one set of controls to operate two robots simultaneously, e.g., maybe for a push test.
You'd need separate radio channels too. Different team radio packets on the same channel can cause interference if the timing of the packet transmissions happen to overlap and garble the messages, making the robot response jerky.
Setting the team number/channel kevin.fort Programming 1 14-02-2006 17:05
Firefly on the Sci-Fi channel EddieMcD Chit-Chat 11 12-09-2005 12:47
FIRST on the Science Channel mtaman02 General Forum 8 22-11-2003 22:39
#FIRST Channel/Chatroom on the efnet Jamie_Richard General Forum 10 03-03-2003 14:30
Robots and the Learning Channel.... archiver 2000 0 24-06-2002 00:16
