Legality of pnumatic ball launcher systems
I've been reading about the different ways to create devices based on pneumatic cylinders to launch the ball. i would like to explore a few of the methods and rules and question what first is going to say about some the pneumatic rules issues
First i would like to question the use of pneumatic cylinders as Gas springs witch are allowed by R87. this means plugging an end of a pneumatic cylinder and using the trapped air as a working gas. and by some means cocking this mechanism either by a winching it in with a motor, or manually cocking the device by hand before a match. Quote:
if the device described above is considered a pneumatic component then the cocking action of this device would be compressing air and is therefore in violation of R93 Quote:
however if this device is cocked by pressurizing the opposing side of the cylinder to a greater pressure with your pneumatic system, then venting that pressure to release the device. Is this trapped air considered part of the “Working” air pressure described in R89? Quote:
additionally if this device were considered a pneumatic component it would need all the Required equipment dump valve, pressure gauge, etc... i suppose if a cylinder were plunged in the opposite fashion in order to pull a vacuum while cocked, this would not apply to R93 as pneumatic pressure is not being generated, rather a vacuum is being pulled in the empty space and then the device is allowed due to R87 Quote:
Re: Legalality of pnumatic ball launcher systems
I think they are talking about gas shocks, like used to hold up hatchback trunk lids and such, not an actuall cylinder. we used a pair of shocks last year, they are completly closed and dont require air input or output, it just compresses ther Air allready inside.
Tytus-
Excellent points. The FIRST Q&A system has addressed many of the concerns that you raise. Those that are considering a pneumatic launch system would be wise to familiarize themselves with these Q&A answers. Your concern about making sure a team with such a system is prepared and not surprised when they get to the inspection table is right on target. The topic of using pneumatic cylinders as gas springs is addressed in this Q&A answer (you can't do it). Mechanically compressing the cylinder to create a working pressure higher than 60 psi is addressed in this Q&A answer (you can't do it). And the idea of mechanically restraining a pressurized cylinder and rapidly releasing it to launch a Trackball is addressed in this Q&A answer (you can do it under certain conditions). -dave . |
I'm curious as to if you can depressurize an end of the cyllinder such that it's actually less than atmospheric pressure, theoretically achieving the same results but also technically within legality of all of the Q&A answers. Depressurisation would be achieved in a similar (but reversed) manner to what's described.
Update #6 says that the rules say that a solenoid must be connected to a cylinder with 1/8" tubing. I can find no reference to this in the rules.
We were planning to connect the valve directly to the cylinder, using "off the shelf" 125 psi fittings, as permitted in rule R88. Is anyone aware of any rule in section 8.3.9 that would preclude this? Also, we are planning to store air in the Clippard tanks downstream of the regulator, at 60 PSI, instead of 120. Is anyone aware of any rule that would preclude this? |
Nope. You will get less air in the system, but that is your choice.
Question, why would you want to do this? I can't think of any advantage to it.
It would seem that a tank that simply stores air would allow for faster response times if it's closer to the target consumer than all other consumers, espeically during times of large air consumption. Not sure of how much performance gain there is overall, but if the target consumer is short stroke and/or timing critical I can imagine it's a big enough difference.
Re: Legality of pnumatic ball launcher systems
Thanks for your replies regarding the legality of using the Clippard tanks for low pressure storage.
How about the first question?: Update #6 says that the rules say that a solenoid must be connected to a cylinder with 1/8" tubing. I can find no reference to this in the rules. We were planning to connect the valve directly to the cylinder, using "off the shelf" 125 psi fittings, as permitted in rule R88. Is this legal? |
#11
I'd think the main disadvantage in using a vacuum in a cylinder for energy storage is that you only get -15 psi (negative one atmosphere) pulling pressure at best, or a quarter of the pushing pressure available with a +60 psi line. You just can't pump it down any more than that.
Steve |
#13
however i haven't tried this for myself yet and weather or not it works is still a mystery to me. prehaps someone else could tell us about their oun experment in this thread. Quote:
| Ball Launcher | Joe_Widen | Kit & Additional Hardware | 15 | 06-03-2006 02:59 |
| Ball Feeding Tube Legality | phrontist | Rules/Strategy | 4 | 13-02-2006 22:30 |
| 612's ball launcher - prototype | jskene | Robot Showcase | 8 | 05-02-2006 11:22 |
| 1266's Ball Launcher prototype! | NiGhtMarE_AnGeL | Robot Showcase | 16 | 30-01-2006 19:55 |
| Legality of Blocking Ball Chutes | Aignam | Rules/Strategy | 29 | 12-01-2004 14:32 |
