Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Unread 30-01-2008, 07:22
itsme itsme is offline
FRC #2217 (FOMH)
Rookie Year: 2007
itsme is an unknown quantity at this point
Question about partial piston stroke
My team wants to make a partial stroke.
What I mean is the following:
A joystick button is pressed-->piston starts to open
Another joystick button is pressed while pitons opens-->piston stops.
How do we do that?
We have tried to put another single solenoid after the main double solenoid.
It partly worked: when we pressed the second button, the piston stopped, but then started to come back slowly.
We are trying to do this to prevent the smack of the piston on the robot (it raises an arm).
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 30-01-2008, 07:31
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
Team Role: Coach
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: Question about partial piston stroke
I think that you must to use a special valve to regulate the flow pressure!!!!
Unread 30-01-2008, 07:38
sloteera's Avatar
AKA: Rafa
Team Role: Coach
Cause the control of the solenoid is made with spike, and spike unfortunately haven't break condition as Victor
But, if you can control the flow pressure, you can stop you piston in any position...
Unread 30-01-2008, 07:55
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The pneumatic cylinders we use (please don't call them pistons) are designed to be fully open or fully closed. It is possible to stop one mid-stroke but it's not very easy.
It would make a great off-season project but I wouldn't attempt it this far into the build season.
If you are worried about speed you can use the flow control valves.
If you want to achieve multi-stroke just put two cylinders together.
Good luck.
Unread 30-01-2008, 08:00
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
There is no way to control the position of a pneumatic cylinder without mechanical stops. Once air enters the cylinder, the piston will move based on the air pressure and the force it is trying to move. If it can overcome the force it is trying to move, it will move until it comes to the end of it's travel (a mechanical stop inside the cylinder). You can control the speed at which the cylinder is moved by using flow control valves at the ports of the cylinder. There is a tradeoff in the time it takes to travel.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-01-2008, 08:14
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
You can use a double solenoid valve with a spring return center off position to stop a piston in mid stroke. You can get vavles from SMC that look nearly identical to the double solenoid valves we recieved in the kit but are about 1 cm longer that will accomplish what you want.
Unread 30-01-2008, 09:00
sloteera's Avatar
AKA: Rafa
Team Role: Coach
Hey...
I don't know if allowed to use Norgren valves on robots, but, they have some Proportional Valves...
I think that theses valves can satisfy your case!!!!
Unread 30-01-2008, 09:55
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
You want an smc SY3340-6H, which is a three position, close center valve. The one in the KOP is a two position, so it won't stop in the middle. Warning: when a cylinder stops halfway, it will be "spongy" because its air holding it. If its a light load, it might be OK. Be forewarned, when it drops, it will drop quickly for a small amount until the air is compressed on the drop side.
Brian K
Team 1225 Robotics Mentor
Unread 30-01-2008, 10:30
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
You can send the vent from the first valve to another valve. The first controls direction and the second is stop/go. There are some nuances to this method but and old team I was on used it with moderate success.
Unread 30-01-2008, 13:18
FRC #2217 (FOMH)
Rookie Year: 2007
Do you mean the regulator? I tried to put down the pressure so it'll move slower, but no success.. It just didn't move because it didn't have enough force.
Unread 30-01-2008, 15:29
IndySam's Avatar
This is the flow control fitting that comes with the kit. You use it instead of the standard fitting. The little white knob controls how fast the air fills the cylinder giving you control of the speed but it will still deliver the full 60psi.
Limited stroke? Brad Voracek Pneumatics 12 18-01-2008 17:53
Robotics in Medicine - Stroke Therapy JohnBoucher Math and Science 1 10-07-2007 15:19
Piston question Spiffizzle Pneumatics 3 10-01-2007 21:17
24" Stroke 1.0625" Bore Piston Legality Yan Wang Pneumatics 4 05-02-2005 09:32
Partial Nick Mac Off-Season Events 11 17-06-2003 22:50
