Go to Post Physics is not a religion. - Jack Jones [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #16   Spotlight this post!
Unread 30-01-2008, 13:38
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Re: Splitting the chain
I got a fairly inexpensive chain breaker from MFG Supply http://www.mfgsupply.com/m/c/32--1733.html
its only 11.95! that is almost 3 times cheaper that grainger, and 10 bucks cheaper than mcmaster
I got master links from MSC (the company that provides the master links in the kit)
If you need an exact product number, PM me and Ill be able to dig for it
they ship really fast too!
  #17   Spotlight this post!
Unread 30-01-2008, 13:57
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Originally Posted by Greg Needel View Post
The reason that you can't hammer it out is a factor of the way the chains are made, the pins are pressed in which causes an expansion of the area on the outside of the pin. In most cases this is a good thing because nobody wants their chains to just fall apart during use.
While I typically support using the correct tool for the job chain breaks are particualrly good if you intend to re-use the pin for a half link or just taking one part of the chain away. Either way you will have a tough time getting the pin all the way out of both the outer and inner links with a break. For that reason I advocate using a dremel tool with a grinding bit.
Take the chain and put it in a vice and just grind the surface of the pin off until you can see marks on the outer link at that point you should be able to remove the pin by tapping it with a punch. If you want the pin completely out repeat this step on the other side and the pin will almost literally fall out. The other good thing about this method is it doesn't matter what pitch (size) the chain is.
Chain notes: The chain in the kit is #35 or 3/8 pitch. If you need to buy sprockets or more chain asking for either one of these will get you what you want as they are interchangeable terms.
We've never had a problem using a break. The problem with your method is at the competition you aren't allowed to grind metal or use any tools that create sparks.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #18   Spotlight this post!
Unread 30-01-2008, 14:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The upside is that you probably will have a much easier time finding a chain breaker at an FRC competition, than you will finding one at a store!
  #19   Spotlight this post!
Unread 30-01-2008, 14:58
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Grainger will also have them. I did a search and the closest store is at
31 Cabot Rd
Woburn, MA
(781) 933-9254
I would highly recommend purchasing a chainbreak. Here is a link to Graingers chainbreak http://www.grainger.com/Grainger/items/1A911
Originally Posted by NOV8R View Post
We got our chain breaker from Lowe's last year. They also have #35 chain and master links.
We just purchased the chain detacher from Grainger and it is the same one that they bought at Lowes
  #20   Spotlight this post!
Unread 30-01-2008, 19:05
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
I just grind down the pins and a little bit of the link plate on one side on a bench grinder. It's very easy to tap out with a punch when you are done. If you need to replace chains at the competition, I'd suggest something is amiss with your build, unless you are redesigning on the fly.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
pic: Revenge of the Chain Fighter Fireworks 234 FIRST Tech Challenge 4 06-06-2006 16:44
Splitting of teams lunchbox1126 Championship Event 2 02-04-2004 14:13
and so the chain reaction beings... Anton Abaya General Forum 1 07-12-2001 22:59
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
