Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 30-01-2008, 14:27
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Is the lane divider IR-opaque?
Edit: The answer has been found. The lane divider is transparent to IR signals.
This came up in the IR-interference thread while I was thinking about how much opponent-caused interference a team might expect.
If IR signals cannot pass through the material the lane divider is made of, then you will be fairly protected from opposing team's signals at the start of the match. On the other hand, robots would have to be completely autonomous once they go behind it from the robo-coaches perspective.
So can anyone out there do a test with a remote, IR board, and a sample of whatever material the lane divider is primarily made out of?
Hmmm... the rulebook doesn't seem to give a specific material: "The openings in the railing panels are filled with clear plastic to prevent portions of ROBOTS from inadvertently passing through the structure."
Research as I go:
If it is polycarbonate and the remotes transmit with a wavelength that isn't around 1660nm (HowStuffWorks indicates that a typical remote transmits at ~800-900nm), then it seems it would be fully transparent and cross-field IR communication will be possible.
Unread 30-01-2008, 14:47
Bongle's Avatar
Re: Is the lane divider IR-opaque?
Replying to myself to close this off:
The divider is polycarbonate1. Polycarbonate does not block IR signals with wavelengths in the 800-1000nm range2. Remotes transmit at 980nm3. Therefore, the lane divider will be mostly (90%) transparent to IR emissions.
Sources:
(1) Page 13 of field drawings: http://www2.usfirst.org/2008comp/Dra...8_Field_GS.pdf
(2) Wikipedia: http://en.wikipedia.org/wiki/Image:P...ansmission.png
(3) HowStuffWorks: http://electronics.howstuffworks.com...e-control2.htm
Legal? Hurdling Over Overpass and Over Lane Divider 7-11number1 Rules/Strategy 11 20-01-2008 14:58
Questions regarding lane divider CVHSARG Rules/Strategy 2 07-01-2008 22:11
Pheasant Lane Mall Unveiling Pamela Thanks and/or Congrats 1 14-02-2002 15:42
