Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Unread 30-01-2008, 15:30
Mr Monte 83 Mr Monte 83 is offline
FRC #0321
Mr Monte 83 is an unknown quantity at this point
Programing the compressor and pressure switch in easy C
help me please, i need to know how to figure out how to program the compressor and pressure switch in easy C
Unread 30-01-2008, 15:39
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Re: Programing the compressor and pressure switch in easy C
Drag InitPressureSwitch() function block into the Initialization function block. Select your pressure switch port (Digital in on RC) and the compressor relay port (relay out on RC). That function only has to be called once (by you) and will check the pressure switch every 500ms. That's all.
P.S. If you need any help at the Philly Regional, I'll be there as a Robot Inspector again. I had fun working with the Robolancers last year and I would be happy to help again.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Question about the Pressure Switch Bomberofdoom Pneumatics 3 24-01-2008 11:00
Compressor and The Presser Switch Shomron1690 Pneumatics 1 11-02-2007 11:12
what is the pressure switch? Reaper40 Pneumatics 2 25-01-2007 18:52
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
