Go to Post Honestly, I'd volunteer my team to be on that alliance. It'd be an honor to touch bumpers with those bots. - ttldomination [more]
Unread 30-01-2008, 18:13
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
Team Role: Leadership
Rookie Year: 2007
SuspectZero is an unknown quantity at this point
large cim motors?
i uinderstand that we cannot use the large cim motor (provided last year, the 3" one i believe) to drive the robot this year. can it be put to use in some other manner, such as lifting an arm for example?
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
Unread 30-01-2008, 18:15
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: large cim motors?
The only motors allowed to be used on the robot are the ones provided in the kit, regardless of their intended function. So no, you are not allowed to use that motor at all on your competition robot.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 30-01-2008, 18:21
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
The manual is your friend.
Here is the relavent sections:
<R58> Motors, pumps, and, Robot Controllers from previous robots shall not be used in addition to those provided in the 2008 Kit Of Parts. They may be used as direct one-to-one SPARE PARTS for those provided if the provided part fails or is damaged. They can only be used if
they are identical to the part being replaced.
• Note that the Fisher-Price motor found in the 2008 Kit Of Parts (Part number 00968-9015) is different from the Fisher-Price motors used in most previous FIRST competitions. Only the Fisher-Price 00968-9015 motor may be used as a SPARE PART
for the Fisher-Price motors provided in the 2008 Kit Of Parts.
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
• All motors, actuators, and servos provided in the 2008 Kit Of Parts,
• HITEC HS-322HD servos,
• FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
• FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
• One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
<R60> Items specifically PROHIBITED from use on the ROBOT include:
Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R59>.
• Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic
solenoid valves – the latter are permitted, the former are not).
Emphisis mine.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 30-01-2008, 18:39
2254 Team President
Rookie Year: 2007
ok so if my understanding is correct, 2" cim motors from last year or the year before cannot be used unless they are used as a back up. we have 4 cim motors currently driving our robot (2 from last year and 2 from this year) and we are planning on using one more (from last year or 2 years ago) to lift an arm. is that still not allowed?
2008 FRC: TBD
Unread 30-01-2008, 18:43
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
You can't use a 5th CIM motor. You're limited to 4 CIM Motors.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2008, 18:44
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The one on the arm is NOT allowed, unless you have three or fewer on your drivetrain (<R59>). The drivetrain you have now is legal, per this Q&A.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Sprocket on large CIM s_forbes Motors 9 29-01-2006 23:01
Large Cim Motor? Fishdude404 Motors 1 27-01-2006 22:36
Large CIM Gary Bonner Motors 2 24-01-2006 19:57
Large CIM Motors - Removing the sprocket PuiChi Motors 5 13-01-2006 16:01
