Go to Post if your true love is building robots, this makes perfect sense - EddieMcD [more]
Unread 30-01-2008, 20:23
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Multiple SPIKES wired to same fuse
Does every spike need it's own 20A Fuse (upstream) or can multiple SPIKES be wired to one 20A fuse if the current draw on M+ and M- is low e.g (powering solenoids on pneumatic vales)?
Unread 30-01-2008, 20:28
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
Re: Multiple SPIKES wired to same fuse
According to the RULES, every SPIKE needs its own 20A breaker (in addition to the fuse right on it).
Unread 30-01-2008, 20:37
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I can't find this specifically in the rules, but it seems implied by <R55>. Maybe you can show me the rule you are thinking of, because I can't find it. You are right about the 20A breaker, although, on the compressor at least, you don't need the fuse along with the breaker.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 31-01-2008, 11:09
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
<R55> All active circuit breaker / power distribution panel branch circuits shall be protected from
overload with an appropriate value auto resetting Snap Action circuit breaker from the Kit Of
Parts....
 Relay modules must be protected with a 20A circuit breaker.
Followed by...
<R56> Each power regulating device (Victor speed controller or Spike relay) shall control one and
only one electrical load (motor, actuator or compressor). Multiple low-load devices (e.g.
pneumatic valves) may be connected to relay modules (but only one motor may be
connected to each relay module).
The electrical principle is simple, based on total Spike failure. Each Spike is fed with a #18 wire and each #18 wire must be protected with a 20 amp circuit breaker.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 31-01-2008, 11:50
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
I'm not sure I am in agreement. I interpret this differently. Perhaps this is a question for the First Q&A.
<R55>
• Relay modules must be protected with a 20A circuit breaker.
Relay Modules is plural (more than 1) with a single breaker.
Unread 31-01-2008, 12:09
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
<R55>
Go ahead and ask FIRST Q & A if you'd like. But, my money is on Al's interpretation.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 31-01-2008, 12:12
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Rookie Year: 2007
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Ask the Q&A, and if you are allowed to wire them together, print the answer and bring it to the competition. Without a direct answer from the GDC, you are likely to get grief from the robot inspectors no matter how the rule is intended. I know last year our chaining of all of the negatives from spikes controlling solenoids didn't fly with the inspectors.
Unread 31-01-2008, 13:22
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
As the Chief Inspector for FIRST, I STRONGLY encourage that someone address this via Q&A. I could give you my interpretation and whether I would allow multiple Spikes on the same breaker but my preference is to make this "official" by using the Q&A.
Also, I didn't sense any interpretations in Al's response. I don't think that he explicitly stated whether he would allow or disallow multiple Spikes per breaker. He did, however, state something very important - trying to actuate a pair of 20A Spikes simultaneously on a single 20A breaker (as an example) is asking for "failure" (ie an open breaker) and should be avoided based on solid engineering principles. IF multiple Spikes per breaker are allowed, 18AWG wire must certainly be used everywhere (per rule <R47> with a single exemption for pneumatic valves).
Russ
Unread 31-01-2008, 14:35
Asked.
To add to the confusion, I am also named Al. So Rosiebotboss is correct either way....
Unread 31-01-2008, 15:01
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Asked.
Did your question include daisy chaining the grounds to spikes? I would also like to see that clarified.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 31-01-2008, 15:05
Unsung FIRST Hero
Rookie Year: 1996
So as to allay confusion, I am Al, AKA Big Al, Al S, Mr. S or Mr. Skierkiewicz depending on the age of the person who is addressing me, what First program you are in and the length of time we have competed with each other. Certain others have used other unauthorized names when addressing me, Dana included. We won't go there, thank you very much.
As to the Spike vs. Breaker controversy, we have been warned in the past about "lawyering the rules". As a broadcaster, single points of failure are to be avoided at all costs. As an example, if the same breaker were used on on two Spikes, one to ingest the ball and one to eject the ball and the breaker tripped preventing you from doing either why would you design your robot to only use one breaker?
To respond to Daniel above. I would have ruled the same. The current that flows in the red wire is the exact same current that flows in the black wire. As you described the wiring you could have had a single #18 wire passing the current of several 20 amp breakers and Spikes. For instance, 4 Spikes fed from four 20 amp circuit breakers each feeding say 10 amps would then cause 40 amps to flow in the #18 wire you daisy chained for the negative return leads. Potentially, 80 amps could flow in the #18 without any circuit breaker trip.
Al
WB9UVJ
www.wildstang.org
Unread 05-02-2008, 20:16
Update 8:
Each relay module must be protected with one and only one 20A circuit
breaker.
Unread 06-02-2008, 00:11
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Still doesn't answer the question...
If multiple spikes are connected to a single breaker,
each spike is still connected one, and only one, circuit breaker.
Now, if they would have said:
"Each 20A circuit can protect one, and only one Spike.", that would be a different story.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
NEED HELP RUNNING MULTIPLE FUNCTIONS AT SAME TIME!! rushrtr3 Programming 1 12-02-2006 02:01
Same bore, same stroke, same mounting--is it legal? Billfred Pneumatics 2 20-02-2005 00:41
Combining multiple objects in different files into the same scene and file? DinkyDogg 3D Animation and Competition 8 19-02-2005 19:14
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
