is this legal?
Is is legal to cut off the threaded attatchment part on a pneuamtic cylinder?
Here's a reference picture: http://www.andrewsmachine.com/pneuma...ges/bimba3.jpg Its the threaded part on the right end. Thanks for your help! Natalie, 604 |
Re: is this legal?
The short answer is, no.
Per R92: Pneumatic components... ...can not be modified except as follows: - Removing the pin from the rear of an air cylinder is allowed as long as the cylinder inself is not modified. Do not, for example, file, machine, or abrasively remove any part of an air cylinder. (I am assuming that you want to use the cylinder as a pneumatic component.) Is there another way that you're looking to mount the cylinder? I can't think of an advantage cutting off the mounting end would have... Maybe we can help you to determine a better/legal way to mount the cylinder? Bengineer |
Re: is this legal?
we're using two small ones(i dont know the exact stroke at the moment), one on each transmission.
unfortunately we didn't calculate the distance they would take up when actually fit into our chassis, so the backs(threaded parts) interfere with eachother when mounted. It was a calculation error on our part, i think we might just have to go with a shorter stroke because its too late to adjust tranny plates and it would just be either a horrible mess or a pain(or both) to re-drill holes on our chassis to off-set the transmissions. no worries =), thank you for your help! natalie |
Re: is this legal?
To over come this problem last year, we had an interface that offset the pneumatic cylinders on each side of the transmission. see here
http://www.chiefdelphi.com/media/photos/27738 (the piston axis and the actual shifting axis aren't in line. it was the opposite on the other side so the cylinders would clear) but we dont want to do that this year |
Re: is this legal?
If you shorten the stroke, won't put your gears at risk for not being fully engaged? |
Re: is this legal?
You could keep the wheels in the same spot and offset the gearboxes by a slight amount so that the pistons no longer interfere. This is what we are doing and I have seen many teams do this.
| Is this Legal? | Torboticsmember | Rules/Strategy | 2 | 07-01-2008 19:28 |
| help is this legal | minion master | Electrical | 7 | 14-02-2007 13:29 |
| Is this legal | IndySam | General Forum | 19 | 26-03-2006 20:34 |
| Is this legal | Bob92 | General Forum | 36 | 24-02-2005 15:10 |
| is this legal? | archiver | 2001 | 2 | 24-06-2002 00:58 |
