Go to Post All hail the amazing duct tape and the mighty zip-tie!!! :] - Gabe [more]
Unread 31-01-2008, 13:03
reader_girl932's Avatar
reader_girl932 reader_girl932 is offline
Rule Czar of Team 1641
AKA: Tina
FRC #1641 (Where's Waldo?)
Team Role: Marketing
Rookie Year: 2007
reader_girl932 is an unknown quantity at this point
What would a component be?
I have read the definitions and the section carefully, but I'm not understanding what it's telling me.
Our robot is made from carbon fiber and it's all put together, but the handbook said that one component can't be over $400 USD. We all use the carbon fiber that is pieced together, but would that be considered one component.
Please help.......
Unread 31-01-2008, 13:09
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: What would a component be?
It seems fairly straightforward.
8.2 DEFINITIONS
COMPONENT – A ROBOT part in its most basic configuration, which can not be disassembled without
damaging or destroying the part, or altering its fundamental function.
 Example 1: raw aluminum stock, pieces of steel, wood, etc., cut to the final dimensions in which
they will be used on the ROBOT, would all be considered components. Bolting pieces of
extruded aluminum together as a ROBOT frame would constitute a MECHANISM, and the
collection of pieces would not be considered a COMPONENT.
Add "carbon fiber" to the list of materials in Example 1. Does it make sense in your situation now?
If you cut a robot frame from one large piece of material, the frame itself is a component. If you make several pieces and fasten them together to make a frame, the frame is a mechanism and each individual piece of the frame is a component.
(since 2004)
Unread 31-01-2008, 13:11
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
I think you asking to the effect of, "We bought a sheet of carbon fiber thats more then $400. Can we use that one piece of carbon fiber to make many parts?" If that is what your asking, then yes, you can. It would be the same as buying all the carbon fiber seperately for each part. Most teams buy bulk in the sense that they order one 60" piece of Al sq tube instead of four 15" pieces of square tubing. So, as long as you break the carbon fiber into pieces that have an equivalent value or less of $400, then you should be ok. Sorry for being a little wordy there, I thought it was the best way to explain it.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 31-01-2008, 13:18
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
That applies only if carbon fiber was available in smaller pieces that cost less than $400. See 8.3.5.1, this bullet point:
The cost of items purchased in bulk or large quantities may be prorated on the basis of the
smallest commonly available unit that satisfies the need for the item.
o Example: A team purchases a 4' x 4' sheet of aluminum, but only uses a piece 10” x 10”
on their ROBOT. The team identifies a source that sells aluminum sheet in 1’ x1’ pieces.
The team may cost their part on the basis of a 1’ x 1’ piece, even though they cut the
piece from a larger bulk purchase. They do not have to account for the entire 4’ x 4’ bulk
purchase item.
Of course, if they buy a piece for $395 and cut 7 parts out of it, the cost of the parts in total is $395.
(since 2004)
Unread 01-02-2008, 17:13
AKA: Tina
Rookie Year: 2007
Okay. I understand all of that, but would welding the pieces together make it a component or a mechanism? When we cut the pieces and weld them together will that make it a component or a mechanism? This was one of the other questions that I had in the back of my mind.
Unread 01-02-2008, 17:17
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Welding would probably make it a component. You can't take it apart without damage/destruction, can you?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
pic: What Would Woodie Do? FourTwoNineZero Extra Discussion 25 21-11-2007 18:11
What would you prefer? Tottanka General Forum 34 06-08-2007 12:35
what what would you like to see in a team website? fimmel Website Design/Showcase 24 08-11-2006 08:32
What would you do? Deej General Forum 8 25-11-2002 12:43
What would we do without ChiefDelphi? AWiser Chit-Chat 16 23-01-2002 14:17
