Go to Post yeah, right - like anyone's going to pass up building a robot. - IbleedPink233 [more]
Unread 31-01-2008, 13:08
OMAR_567 OMAR_567 is offline
FRC #2595
OMAR_567 is an unknown quantity at this point
NEED HELP WITH PROGRAMMING
HEY
WE ARE A ROOKIE TEAM AND WE HAVE NO IDEA WHAT TO DO AND WE WANT TO SEE A SAMPLE CODE IN TELEOPARATED MODE ANY HELP????
Unread 31-01-2008, 13:38
iwin2000 iwin2000 is offline
iwin2000 has a spectacular aura aboutiwin2000 has a spectacular aura about
Re: NEED HELP WITH PROGRAMMING
Maybe you shouldn't yell and people would help.
But are you programming in EasyC or MPLAB?
Unread 31-01-2008, 13:40
FRC #2595
MY BAD WASNT TRYING TO YELL
WELL WE ARE USING MPLAB
Unread 31-01-2008, 13:44
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Go download the default code. Open up user_routines and read the comments. It should have enough code to get your robot driving as is.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 31-01-2008, 14:11
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
Rookie Year: 1999
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
In general when 'speaking' on the internet, using ALL CAPS is considered yelling. That's what iwin2000 was probably getting at.
By the way, the default code can be found near the bottom of the this page. It's labeled '2007 RC Code'. If I remember correctly, IFI hasn't released any different code for the 2008 season. If I'm wrong, someone will almost definitely correct me ^_^
Unread 31-01-2008, 14:52
FRC #2595
We have gone through the default code, but we are missing what the code means. We have someone to help us with C programming, but how do we define things so that they match up with physical layout on the robot control. Is there some manual that helps explain some of this. For example:
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
The comments help in the program, but we need some more direction.
Unread 31-01-2008, 14:57
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Take a look at the IFI user guide to the default code: http://www.ifirobotics.com/docs/lega...e-2004-1-7.pdf
Also see http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf
Both are linked from the IFI webpage that CardcaptorRLH85 refered to.
Unread 31-01-2008, 14:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Programming reference guide:
Default code reference guide:
Brian K
Team 1225 Robotics Mentor
Unread 31-01-2008, 15:06
Imaginary Friend
AKA: Kevin Li
Team Role: Student
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
pwm05 = p1_x;
pwm06 = p2_x;
pwm07 = p3_x;
pwm08 = p4_x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
Basically what's going down below is that the pwm outputs on the robot controller are being mapped to the joystick inputs on the OI. So if you plug in a joystick to port 1 of the OI, and push it foward all the way, p1_y will be 255. This 255 on the Pwm01 will tell the speed controller to go +12V across the motor. Pulling it all the way back would give you a 0 on pwm01. This is a signal to go -12V for the speed controller(running a motor in reverse). When the joystick is at rest it is at a neutral value of 127.
So with what's setup below if you plug in joysticks to the OI in ports 1 and 2. Then plug in your speed controllers for your drive into PWMs 1 and 2. Then you should be able to drive your robot with 2 joysticks.
pwm01 = p1_y; //Map the y axis of joystick 1 to pwm01
pwm02 = p2_y; //Map the y axis of joystick 1 to pwm02
pwm05 = p1_x; //Map the x axis of joystick 1 to pwm01
pwm06 = p2_x; //Map the x axis of joystick 1 to pwm02
Kevin Li
596 - Sciclones
Need Help With Maplab C programming on serial communication loveheb3 Programming 0 04-06-2007 21:24
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
Need help programming our swerve with feedback? activemx Programming 25 13-04-2004 07:29
need help with programming magical hands Programming 1 11-02-2004 22:12
Need help with programming Kori E. Programming 7 24-02-2003 21:21
