Go to Post I wouldn't mind having this day repeat itself a few times. It would give us more time to work on our robot. - Mr.D [more]
Unread 31-01-2008, 13:33
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Regularity of RepeatingTimer interrupts?
How accurate can I count on the trigger timing of ISRs registered with RegisterRepeatingTimer() to be?
I have the idea of using a repeating timer to do regular velocity calculations on the two quad encoders attached to my gear boxes. Basically the ISR would read the encoder counts, subtract the previous counts from each to get the differences, and divide by the repeating timer interval (most likely 256ms, so I can divide using bit shifting). The resulting velocities would be stored in global variables to be accessed by my PID code running in the "default" loop.
Will this work?
Unread 04-02-2008, 07:42
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Regularity of RepeatingTimer interrupts?
The code resets the timer value as the first thing when the interrupt occurs, so it should stay pretty accurate. I would think it would be close enough for the calculations that you need to do.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Multiple Interrupts windell747 Programming 13 03-02-2008 03:52
Interrupts JSonntag Programming 1 14-01-2006 12:43
Using Interrupts Leav Programming 1 14-02-2005 07:22
Interrupts CyberWolf_22 Control System 3 12-01-2004 21:46
