Go to Post There are two types of competitors in this world, those who aim to rise above their opponents and those who seek to drag them down. Which group do you want to belong to? Which group is more beneficial to our society? Think about it. - Karthik [more]
Unread 31-01-2008, 13:44
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Ganged Interrupt Edge Detection
Do Interrupts on the RB Port (Ganged Interrupts) have any edge detection registry assignments?
Unread 31-01-2008, 13:53
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Ganged Interrupt Edge Detection
If enabled, all four fire off on both edges. If you are interested in executing an ISR on only one edge, just examine the state of the pin in the ISR and execute your code only when it is at the right logic level (e.g., if it's a one, a rising edge just happened). If you're using my code, I pass the logic level into the ISR for you.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 31-01-2008, 18:11
-Kevin
How should I go about reading that logic level?
-Stephen
Unread 31-01-2008, 18:45
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
That just means 1 or 0 basically
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 31-01-2008, 19:05
And what registry value outputs that information?
Thanks Stephen
Unread 31-01-2008, 19:31
wt200999's Avatar
Texas Instruments
AKA: Will Toth
if you look in the default code in the interrupt handler
Code:
  else if (INTCONbits.RBIF && INTCONbits.RBIE)  /* DIG I/O 3-6 (RB4, RB5, RB6, or RB7) changed. */
    int_byte = PORTB;          /* You must read or write to PORTB */
    INTCONbits.RBIF = 0;     /*     and clear the interrupt flag         */
PORTB is the register. You have to read/write to it before you can clear the flag. Have a look at how Kevin does it in his encoder code, and do you know bitwise operators and the such?
Unread 31-01-2008, 20:00
Yea, but I got the impression that in his encoder code, he used the registry value to distinguish which interrupt had fired, not which edge was being detected.
Unread 31-01-2008, 20:37
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Thats where the 0 or 1 part comes into play. Take a look at the spec sheet and you will see what is in the PORTB register, and also look into bitwise operators (specifically XOR)
Unread 01-02-2008, 10:52
Encoder_3_Int_Handler(Port_B & 0x10 ? 1 : 0); // call the encoder 3 interrupt handler (in encoder.c)
I see it now, the XOR gate operator for Port_B_Delta is to distinguish which interrupt fired. Then the line of code above inputs a 0 or 1 into the function to tell whether a rising or falling edge has interrupted. Thank you for all your help wt200999
rangefinding/object detection sciguy125 Electrical 14 13-01-2008 20:36
Collision Detection in Inventor? jlewellen Inventor 2 06-01-2005 21:29
Cutting edge... Eugene Technical Discussion 9 26-02-2002 02:59
Cutting edge... Eugene Technical Discussion 0 22-02-2002 18:27
Steel Edge AJ Howard Rules/Strategy 1 18-01-2002 18:52
