Go to Post Repeat after me: "The Internet is my friend." :rolleyes: - Bill Moore [more]
Unread 31-01-2008, 14:35
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
FRC #1675 (Ultimate Protection Squad)
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Pneumatics Board/Mounting Components
We've gotten to the point where its time to build our pneumatics board and mount all of our pneumatic componenets. This task has been taken up by the student team I'm leading, as no one else on the team has much experience with pneumatic systems.
I was looking for suggestions about building the pneumatics board. I've noticed that very few of the components apprear to have pre-existing mounting hardware, besides the actual cylinders and the compressor. I'd like to get a pretty clean look with recessed gauges and valves, but my solution thus far has been wrapping them with zip-ties (which I'm sure would work, though perhaps not the most elegant solution). I'm currently leaning towards using 1/8 or 1/16 lexan (pretty much whatever we have around), as thats what the hardware team is using to mount all the electronic components. It would also be great to have any tips you can provide about tube routing, and management.
Any advise or tips you can provide would be great. Thanks.
Unread 31-01-2008, 22:25
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Pneumatics Board/Mounting Components
We usually connect the pneumatic circuit, using the hard fittings between components when possible, and then drill holes in a lexan piece and use small zip-ties.
Do all of your leak checks first, then mount the components.
For example, you can start with a T connector with the electric pressure switch, then use a short threaded coupling, then another T connector with a 120 psi gage, then another short threaded coupling, then another T with the regulator, and so on. Use a connector for the tube fittings at the two ends.
It makes for a combination of components that can be mounted in a solid location.
I will see if I can get a photo tomorrow.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-02-2008, 13:47
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
Im making my P-Board today , ive got all 4 tanks connected together with hard fittings . Im mounting it all in lexan , im not sure the thickness , and the main ( white) pressure gauge is hooked up by the tanks. we have 4 solenoids the 2 regulaters , 2 solenoids are running at 30 and 2 are running at the full 60.
Im using zip ties by the way.
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Custom Pneumatics - Control Board Selection? Erin Rapacki Electrical 3 03-04-2007 17:21
Question on mounting components BQuennell Electrical 7 31-01-2007 12:01
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
pic: #1156 Under Control [Brazil] - Electrical components board Daniel_H Extra Discussion 6 30-01-2005 19:56
Electrical Components? Miles General Forum 5 10-01-2003 08:12
