Go to Post Just think outside the box but inside the 28" X 38" X 60" rectangular prism and you may come up with a solution. - Pavan Dave [more]
Unread 31-01-2008, 16:28
m1k3 m1k3 is offline
FRC #1396
m1k3 is an unknown quantity at this point
ouble valve, with a center CLOSED port.
double valve, with a center CLOSED port.
It's a 3-position valve. SMC has them in the same series as the kit of part valve, only you need the center closed version. i was looking around and found a post about controling extension on a solonoid to hal way can somone pin point the valve i need on the smc website because there is like 100 difrent types of them so if somone could post a link Thank you i need the valve for a doulbe solonoid so i can make the piston go halfway i need one compatible with the solonoids first gave us thank you
Playing with the Content Center KnightOfIvory Inventor 1 29-01-2006 08:03
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Powering with the Competition Port David Bing Electrical 4 17-03-2003 19:30
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
trouble with assembling FESTO valve geo Pneumatics 15 02-02-2003 09:28
