Go to Post Science and Technology is like the tide in the ocean, it raises all ships together, whether they're an engineering ship or a manual labor ship. - Doc Wu [more]
Unread 01-02-2008, 11:24
Aaron_H Aaron_H is offline
FRC #1033
Aaron_H is on a distinguished road
Dead IR Receiver Module
Hey everyone,
We were working with our TinyIR2 IR module that FIRST sent us, and it seems as though the IR module has failed. The symptoms are as follow:
-The board DOES power up
-The board DOES go into program mode (press the button for 2 sec. and release)
-The out0 LED DOES NOT flash in program mode when an IR remote sends a signal.
We tested the remote visually (pulled out the camera phone and shot the IR beam at it...the camera shows a nice purple hue coming from the remote) and even tried several different remotes. I hooked an oscilloscope to the signal output from the IR module and there is no pulse when an IR signal is sent from the remote. We have been running the board from 12V off the circuit breaker panel. Does anyone have any suggestions? Has this happened to you? Also, are there any suggestions for making the ribbon cable more robust?
Thanks,
Aaron
Unread 01-02-2008, 11:43
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Dead IR Receiver Module
Have you checked the +5vdc regulator on that board?
Dozens of posts on this problem. Please search.
Blown regulators are common, mostly caused by reverse polarity.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 01-02-2008, 15:46
FRC #1033
Yes, I did check that the output from the voltage regulator block was 5VDC. If that voltage regulation circuit had been blown, I doubt that all of those other components I listed would work properly.
Unread 07-02-2008, 11:50
FRC #1033
I fixed it. As it turned out, It was the IR receiver module. I desoldered the old one and put in a new one that I bought at RadioShack.
Wiring the IR Receiver Rapt0r9 Electrical 19 29-01-2008 18:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
