Go to Post You are certainly welcome to demonstrate your geekiness on a regular basis! :) - Cynette [more]
Unread 01-02-2008, 12:30
FaNIX FaNIX is offline
FaNIX is an unknown quantity at this point
Restarting Main Application in TThread Class
Hi People,
I am trying to restart my Main Application by using code inside a Thread. Basicly my restart function works 100% when placed inside the Main Application code. But since a TThread runs in another memory space, i think reference to the Application.Terminate is not set to the Main Application, maybe to the thread, I don't know.
Here is my restart procedure inside my Thread:
procedure TUpdateLibThread.AppRestart;
var
HANDLE : HWND;
begin
ShellExecute(HANDLE,'open',Application.ExeName, '', '', 1) ;
Application.Terminate;
end;
The thread is called by die main application, but the restart application must be inside the thread, as the outcome of the thread determines if the application should be restarted or not. If there is a way to return a value back to the main application when the thread ends, then i might be able to use that to determine if i need to call the restart procedure...
Help?
Unread 01-02-2008, 12:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Restarting Main Application in TThread Class
If you are using the Delphi programming language, you might not find a lot of help here. Chief Delphi is a forum for discussing the FIRST Robotics Competition, whose main programming language is C. Some may know Delphi, but most will think of the automotive corporation. This thread may help you find a better location to ask your question.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
changing main.c 3dude_2231 Programming 15 21-02-2007 01:54
main.c 6600gt Programming 3 29-08-2006 02:19
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
