Slowing a piston with full power
Is there a way to make a piston travel slower but with full power?? Like some kind of flow restrictor?
Thanks Bruce |
Re: Slowing a piston with full power
Yes. There are some right angle turns (threaded on one side) in the KOP that have a small white knob on one side. The knob is a flow controller.
One thing to remember about these flow control valves. They control the flow of air LEAVING the cylinder. They do not limit the flow of air entering the cylinder.
-dave . |
A quick study would seem to indicate that one would only need to constrict the flow of air entering the piston on the stroke one wants to limit the speed as the other side is open the atmosphere and just vents. However, taking this to an extreme limit though, if you completely or nearly completely close the needle valve on the vent side then is will limit the flow significantly and slow things down.
So here is my question, is it possible to use various settings on valves on both ends such that on the out stroke you have one speed and then on the in stroke a significantly different speed. a.ka. out - slow .... in - faster Thanks, APS |
You can get them pretty different, just try and see what works best for your application. You can have them on either the solenoid portion or the piston portion, won't really affect it that much since the air flow is mostly controlled by the small diameter of the adapters and plugs more than anything. Last edited by Jeff K. : 08-02-2008 at 02:19. |
You can also try getting a pipe plug and drilling a small hole in the plug and screw it in the exhaust port of the air valve. This will slow the exhaust and therefore slow the piston. It works well and you simply keep drilling out the hole till the desired piston speed is achieved. You can also get adjustable flow control valves. I like the pipe plug trick because once it is correct it can not be adjusted and messed up. I use this in industrial applications all the time.
#10
Just stick with the suggestion to use the flow control valves provided in the Kit Of Parts. They are provided for just this purpose. -dave . |
| need some help with piston | coolguybigt | Chit-Chat | 1 | 03-04-2007 15:22 |
| Tagging Pictures with Full Names | Jaine Perotti | CD Forum Support | 3 | 06-04-2006 09:35 |
| Is FIRST slowing down with it's updates! | mtaman02 | Regional Competitions | 8 | 15-03-2004 23:25 |
| how do i control a piston with a joystick | Ryan Foley | Programming | 2 | 27-05-2003 17:13 |
| Piston power? | archiver | 2001 | 2 | 23-06-2002 22:51 |
