Go to Post Use these tools as a starting point, not as an end product. - Tom Bottiglieri [more]
Unread 01-02-2008, 22:07
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
FRC #1726 (N.E.R.D.S.)
Team Role: Mechanical
Rookie Year: 2007
CCCP will become famous soon enoughCCCP will become famous soon enough
Re: Peumatics or Motor?!?!?!?!
go with the motors
Unread 01-02-2008, 23:04
M'gnad-knockah M'gnad-knockah is offline
FRC #1517
M'gnad-knockah is an unknown quantity at this point
the other downfall to pneumatics is the efficiency, pneumatics only have a 4% efficiency, which sucks because the compressor has to run, and waste battery power.
Unread 02-02-2008, 07:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
where did you get that number?
Unread 02-02-2008, 15:08
FRC #1517
its common knowledge
Unread 02-02-2008, 17:29
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
We don't know it here... Go look at the books again. (Or I know who to ask, when I am at competition.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-02-2008, 20:42
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Actually, without a citation and/or verifiable reference, it is nothing but a common made-up number. Sorry, but saying"pneumatics only have a 4% efficiency " is just not credible without providing more information to back up the statement. Facts are preferred over conjecture.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 02-02-2008, 17:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Assuming this number is true, it needs more clarification. 4% efficiency in what sense? 4% of the potential in the compressed air is converted to kinetic in a moving cylinder? 4% of the electric potential to run the compressor is converted to potential stored in the tanks? 4% of the electric potential to run the compressor is converted to kinetic in a moving cylinder?
Unread 01-02-2008, 19:27
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by emo Sponge View Post
if your arm sticks out you should use peumatics
if it does not use a motor
peumatics are not realy safe
What makes you think that motors are safer than pneumatics?
Both can generate a lot of force and a lot of momentum. Both can be made safe, and both can be very dangerous if used incorrectly.
To Sam2197,
both pneumatics and motors can be used equally effective. If you already have pneumatics in your design then adding a cylinder is far less weight than a gearbox and motor ... but if you dont have pneumatics already in your system then the compressor alone may weigh more than using a motor and gearbox.
In short ... it depends
Good luck and let us know what you used.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 01-02-2008, 19:31
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
currely i have two designs one using pneumatics and one without. i really think we will need more than just those two positions though so i think we will need a motor for this. thanks for the help everyone
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Is it okay to run one motor in a two motor transmission? NoodleKnight Technical Discussion 27 16-12-2004 07:16
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
