Go to Post We can either sit around and complain about what could have been, or we can focus on the upside of what we have and move on. - Vikesrock [more]
Unread 01-02-2008, 22:31
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
How many positions?
In the beginning of the match, How many positions can the ball be located on the upper rack?
Unread 01-02-2008, 22:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: How many positions?
3 positions per side; one ball of each color will be on each side. Random locations are chosen by the field.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 01-02-2008, 22:35
FRC #0870
thanks man, btw, that is a nice new picture may I add.
Unread 02-02-2008, 08:22
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
There are (Per alliance) 3 spots to put your robot. And then there are ~6 positions where your balls could be, One on your overpass, and one on the opposite overpass. Very technical to do automode on the other side of the field this year :\
Min-Max to the Max!
Unread 02-02-2008, 09:44
FRC #0870
thanks man, that helped me out.
Unread 02-02-2008, 09:56
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
I had to check the rules just to make sure of this:
Originally Posted by 7.3.4.1 Starting Conditions
<G15> ROBOT Starting Positions – Prior to the MATCH, the three alliance ROBOTS must be placed entirely inside their HOME STRETCH, touching their Alliance Station Wall or the angled fence in front of their local ROBOCOACH STATION, and not contacting any other ROBOTS.
Not three spots (like the squares in Aim High), but maybe only three locations in practical matters. I can check this afternoon when I get to our roboting. But this is what I wanted to make sure:
<G20> TRACKBALL Locations - ... four TRACKBALLS will be placed on the OVERPASS. On each side of the OVERPASS there are three TARGET LOCATIONS for TRACKBALLS. The field management system will randomly choose an initial starting location for the TRACKBALLS before the start of each MATCH. One red and one blue TRACKBALL will then be positioned in the chosen TARGET LOCATIONS on each side of the OVERPASS. ...
Is the "field management system" a computerized randomization, or just what the field reset crew decides at the moment? And think of what muscles that crew will have lifting those balls all day!
Unread 02-02-2008, 14:30
FRC #0870
thanks a lot for verifying. It is appreciated.
Unread 02-02-2008, 14:42
One T
AKA: Mat
The length of the field makes it so there is only 3 robots length in your home stretch (That is of course unless you make really long and skinny robots, then there are maybe 4.)
|HOME STRETCH|
|bot | bot| bot|
Min-Max to the Max!
Unread 02-02-2008, 21:32
FRC #1153
Rookie Year: 1900
Not quite sure of which is length and width of the field. (I have this trouble all the time at work. ) I was answering this part
The alliance wall and the angled Robocoach station wall are where the robots park up against (and touch). There is about 13-feet from field side to field centerline, divided by say 30-inches per robot (including a gap between), gives you a bit over 5 robots across the alliance walls in the Home stretch starting area.
Unread 02-02-2008, 21:49
One T
AKA: Mat
N There is about 13-feet from field side to field centerline, divided by say 30-inches per robot (including a gap between), gives you a bit over 5 robots across the alliance walls in the Home stretch starting area.
The wall is angled there though, Which leads to one robot sticking out, and if they are 30 inches, it will be touching another robot, which they are not aloud to do.
Min-Max to the Max!
Unread 02-02-2008, 21:58
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
All it has to do is touch not be flush.
Unread 02-02-2008, 22:01
FRC #1153
Rookie Year: 1900
Well, if you have the back of the robot flat against the angled wall, yeah. But "touching" to me sounds like it can be just a corner of the robot touching the wall, but the front of the robot is still facing the overpass (parallel).
Unread 04-02-2008, 10:06
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
The robots may be touching either the wall in front of the driver's station or the diagonal wall in front of the Robocoach area, see <G15>. That gives quite a bit more width to play with, plus might start a speedy lap bot a little farther down the track. Only a corner of the 'bot needs to be in contact with the wall, it does not have to have one side flush. That was covered in Q&A pretty explicitly.
Steve
Unread 04-02-2008, 10:15
One T
AKA: Mat
Ah, i thought it had to be flush against the wall, now i understand.
Min-Max to the Max!
  #15   Spotlight this post!
Unread 04-02-2008, 10:18
Glad I could help
how many vandoors? Justin_302 Motors 8 08-03-2005 18:54
How many SD teams in 05? JP_1163 FIRST-related Organizations 0 01-10-2004 11:50
How many teams.. archiver 1999 8 23-06-2002 22:53
