Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Unread 02-01-2008, 11:57 PM
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Ultrasonic sensors on digital ports 3-6 problems
I wrote a program to run this sensor (Parallax PING))) ) for ports 1&2, and it worked fine, but I decided I would rather have them on ports 3-6 and have 1&2 for my encoders, so I re-wrote my code, and now it doesn't work properly. I end up getting one high number when I first turn on the robot, then a steady number of 35 for the distance and 25 for the time. Here is my code:
http://www.easternfront.org/ultrasonic_port_3_6.zip
I had several printf's spread around in it to see if I was getting to all of the places in my code, thats what that phasetest is. My implementation of it in the default routine is:
Code:
if(x==1)
    Ping(3);
if(x==20)
     printf("Distance:%d Time%d\r",Get_Distance(3),Ultrasonic_3_Time);
     x=0;
x++;
Any help would be greatly appreciated, thank you.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 02-20-2008 02:34 PM
ultrasonic sensor problems... couldntthinkofa Programming 2 01-05-2008 12:29 PM
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 12-01-2007 09:22 AM
can we use ultrasonic sensors? GMKlenklen Electrical 20 01-15-2007 02:34 PM
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 05-22-2006 12:08 PM
