Go to Post Good engineering involves working with constraints, not complaining about them. - Norman J [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 02-02-2008, 09:50
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Powering the IR detector from +5V instead of 7+ V.
Considering that the IR detector board is an input sensor (not an actuator) and it only draws 20ma at most, is there any reason why it can't be modified to run on +5V supplied by the Digital Input connector.
It just seems that this would make it much easier to hookup... getting power and providing signals with just two PWM cables (one conventional and one connected sidways on the DIO pins).
It would require modifying the board a tiny bit (by taking the somewhat suspect regulator out of the circuit and feeding the +5V directly to the output trace of the removed regulator), but this does not appear to violate any rules. As is is, some people seem to be replacing the regulator with a more robust one.
Have I missed anything that would prohibit this?
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Powering the IR Board aznzricex Electrical 1 31-01-2008 11:02
Powering the IR board Dan G. Electrical 3 23-01-2008 01:58
How to make the camera search the light instead of only follow when targeted? jesusescobar Programming 4 18-02-2007 16:56
Powering the RC Mr. Steve Control System 15 06-03-2005 23:21
Powering the RC Mr. Steve Electrical 15 06-03-2005 23:21
