Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 02-02-2008, 13:26
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Problem with negitive numbers
I've been working on a velocity PID for motor control, but I'm having trouble.
When the PID calculation returns a positive value the code runs fine, but when it return a negitice value the motor output begins jumping appearently randomly from very high(5 digit) to very low(-5 digit) values.
Once this happens the PID reacts correctly, but due to the values that a far outside of normal it never recovers.
Here is the code I think contains the issue, but I can't find it. I added some comments to help explain the issue.
Code:
void MotorControl (unsigned char motor)
    //The printfs in CalculateSpeed() give correct data.
	int speed = CalculateSpeed(motor);
	int output;
	//printf("speed on motor %d = %d\r\n", motor);
	//printf("Speed Goal = %d\r\n", speedGoal[motor]);
    // Last line in PID prints the PID output, and it always appears correctly.
	output = PID(speed, speedGoal[motor], &pidInfo[motor]);
 	currentOutput[motor] += output;
	if (loopCount == 0)
          //This is where the issue is obvious. It prints strange values within
          //the same loop as PID() returns a negitive value, and then until reset.
		printf("Output %d = %d\r\n\r\n\r\n", motor, (int)currentOutput[motor]);
	switch (motor)
		case 0:
			MOTOR_ONE = LimitInput(currentOutput[motor] + 127, 0, 255);
			//printf("Motor one set during %d\r\n", motor);
			break;
		case 1:
			MOTOR_TWO = LimitInput(currentOutput[motor] + 127, 0, 255);
			break;
Eric Haskins KC9JVH
Problem with Lofting cooker52 Inventor 14 04-11-2007 15:00
Problem With Footsteps Popper99 3D Animation and Competition 1 04-11-2007 09:34
Problem with RoboEmu2? Calvin Programming 1 12-02-2005 11:27
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
