Go to Post PS: When/if it gets to be too easy to build a machine that can accomplish a recent/typical FRC game, then I suspect it will be time for someone to unveil a harder game. - gblake [more]
Unread 02-02-2008, 13:38
OMAR_567 OMAR_567 is offline
FRC #2595
OMAR_567 is an unknown quantity at this point
Programming Help- 2 Motor 2 joystick Drive System
Can someone help us use change the default code from a one joystick operation to a two joystick two motor drive system?
We will be using a tank drive system. We would like to see some sample code.
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
1 Joystick Drive or yaniv Programming 3 19-01-2005 14:18
Drive System Animation Project help is needed Brian Lesser Technical Discussion 4 12-10-2004 17:09
Control System, Joystick mod? Jordan A. Technical Discussion 16 13-02-2002 02:29
Quick Start Guide - Drive System Help for Rookies Nuts4FIRST Technical Discussion 5 31-10-2001 14:42
