Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 02-02-2008, 15:42
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Supershifter Encoder Reliability Problems?
Ok, so we were driving the snazzy new chassis I posted pictures of recently today, and within just a few minutes our encoders on our supershifters ceased to function. No, it isn't a software problem, I've examined the output of the encoders with an oscilloscope on both sides of the robot. One is almost constantly high (5v) and occasionally comes low if you spin the transmission shaft fast enough. The other randomly gets pulses occasionally when you spin the transmission shaft fast enough.
Has anyone else had reliability problems with the supershifter encoders? We're probably going to end up making a coupler and all then mounting different encoders as the open-frame us digitals (being open frame) are more prone to short life if there is any runout in the shaft of the transmission.
*hint hint* Any suggestions Andy?
-q
p.s. Where are my manners: the shifters pull great and the gear ratios were well figured. Nice shifter. Servo shifting not so hot, switching to pneumatic.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 02-02-2008, 16:14
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: Supershifter Encoder Reliability Problems?
I would open the encoder cases up and check to see what is going on inside of them. When you take the back case off, there is a metal disc inside. Take this disc off, if it comes off with a little struggle, then that part is good. If it loosley comes off, the it was not fitted to the shaft properly. To do this, gently use a pair of pliers to squeeze the four parts that go over the shaft (on the side of the disc facing the transmission) until each gap is closed. Make sure not to close them in too tight. Another thing to check is the side of the disc that faces the transmission (with the near microscopic lines on it) and make sure that there is no debree(sp) or scratches on it. If so then the disc is bad. Make sure to not touch this side at any time. Also make sure the red sensor on the green board is clean. Again do not touch this part. When you put the disc back on, do not push it all of the way down. It is best to use a tool designed to put the disc on, but if you do not have one, leave a little more than a milimeter between the disc and the top of the sensor. Let me know if this helps any!
I win! XD
Unread 02-02-2008, 18:17
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Did you change the shafts or pull them out of the transmissions? If so, you will need to pop the covers off as stated above, and attach the encoder wheels.
Unread 02-02-2008, 20:21
AKA: Alex
We've already examined the encoder wheels and such, and have found no problems with it.
However, what we have nocied is that our super shifter's encoder shaft has more than the allowable axial play listed on the US digital website. By setting the transmission down on a flat table and using a dial caliper, we've discovered our transmission's encoder shafts have about 0.050" play (total, not +/-). So, to remedy this, we're next-day-airing some US digital fully housed and ball bearinged 250ct encoders and installing a HeliCal flexure coupling between the transmission and the encoder to isolate the encoder from possible damage by the transmission shaft.
And, completely unrelated, our plasma cutter quit and crashed (physically) today while running all of the parts for our final version of our shooter, as well as all the brackets to mount our pipes. I've had a rough day.
Thanks for your help and thought,
q
Unread 04-02-2008, 10:38
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Q,
Thanks for bringing this up. We're using supershifters for the first time this year, and I'll have ours checked out tonight before going on the chassis (yes, we are a little behind where we'd hoped to be).
Originally, we weren't aware that there were coders built into the transmissions, so we designed one wheel axle on each side longer than necessary, to extend beyond the bearing and back into the main portion of the chassis, where we had intended to mount COTS encoders. Would something like that be easier for you to do, rather than unmount and disassemble the transmissions?
Steve
Unread 04-02-2008, 12:55
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Q,
We've had some reliability problems with our encoders. They seem to be retuning odd values, or none at all at times. I'm planning to look at the return values with an oscilloscope and some simpler code to see what is actually going on.
Please let us know how the couplings work for you, we might try the same thing.
Problems with Encoder Counting bjimster1 Programming 19 07-03-2007 09:59
Encoder Counting Problems RyanW Programming 1 14-02-2007 15:17
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
