Go to Post it's shadows and fog and stormy skies and a reminder that things are rarely black and white but instead, the places in between. - MissInformation [more]
Unread 02-02-2008, 16:14
p_a_3 p_a_3 is offline
FRC #1648
p_a_3 is an unknown quantity at this point
Unable to resolve ADC_CH0
I have been unable to locate this. In ifi_frc.h is
#define rc_ana_in01 ADC_CH0
Can someone please tell me where it is defined?
Thanks
Unread 02-02-2008, 16:43
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Unable to resolve ADC_CH0
Thanks
If you're using the legacy IFI code in ifi_code.c, you should use the values found in mcc18\h\adc.h (e.g., ADC_CH0, ADC_CH1, etc).
If you're using my code, you just pass in a number corresponding to the channel (e.g., Get_ADC_Result(1)).
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 02-02-2008, 18:06
FRC #1648
Please excuse my confusion here.
The base code we used was located in ifi_frc_sensor_30
The reference to ADC_CH0 was in ifi_frc.h of that project. I suspected that these defines were values 0, 1, etc. When I looked at an old mcc18\h\adc.h I found
#define ADC_CH0 0b10000111 // Channel 0
Should I use these values or simple integers?
Thanks,
Paul Alexander
Unread 02-02-2008, 20:26
FRC #2429
Thanks,
Paul Alexander
I'll have a look at it this evening...
-Kevin
Kevin Watson
http://kevin.org
Unread 03-02-2008, 01:42
FRC #2429
Thanks
Sorry about the confusion. I've written replacement code that has the same functionality as the old IFI code. I'm not sure how I'll incorporate it yet, but you can download it here and drop it into your project.
-Kevin
Kevin Watson
http://kevin.org
Unable to see the sensors or pneumatics manual Chaos204 General Forum 5 06-01-2008 13:11
Help! unable to locate 'p18cxxx.h' ducttapehaxor Programming 1 24-01-2006 16:13
Error: Unable to locate 'stdio.h' phrontist Programming 4 09-02-2005 19:59
Unable to transfer Document in Streamline squide 3D Animation and Competition 12 16-02-2004 23:40
