Go to Post I saw Dave Lavery on the Webcast. And he winked at me! - Tetraman [more]
Unread 02-02-2008, 20:12
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
we need help with PWM problem in autonomous
We're getting strange pwm trouble in Autonomous Mode. If I put pwm13 = pwm14 = 127 in User_Autonomous_Code(), the speed controller's LED are green and motors turn. If I use pwm13 = pwm14 = 0 or if I use pwm13 = pwm14 = 255, both make LEDs turn off and motors spin opposite. If I do this in the default routine, it works right: 127, LEDs are orange; 255,green and 0 red.
Can anyone tell my why the PWMs act different in Default and Autonomous?
here's the code in User_Autonomous_Code() :
/* Add your own autonomous code here. */
Remote_Controls();
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
void Remote_Controls()
// if Remote # 2 is pressed, stop
if (rc_dig_in02==0)
pwm13 = pwm14 = 127;
pwm15 = pwm16 = 127;
// if Remote # 3 is pressed, backup
if (rc_dig_in03==0)
pwm13 = pwm14 = 0;
pwm15 = pwm16 = 0;
// if Remote # 4 is pressed, fwd
if (rc_dig_in04==0)
pwm13 = pwm14 = 255;
pwm15 = pwm16 = 255;
Unread 02-02-2008, 20:23
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: we need help with PWM problem in autonomous
in your code where it says
if (rc_dig_in13==0)
You need to put == 1 If you are looking for 0 that means you never pressed a button. If you press the stop button with your code it makes it 1, so it skips the if statement you want it to go to, and goes to the reverse one. I think I explained it ok, if I didnt, ley me know.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 02-02-2008, 21:23
FRC #1277
rc_dig_in13==0 means the switch is closed; on the robot controller's digital input/output port, the white and black lines are connecting.
But that has nothing to do with why pwm13=127 makes the speed controller go full forward, like I said above.
Unread 02-02-2008, 21:26
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
When you say pwm13=127, is that within one of the IR ifs or just a direct assignment? There should be no reason the code is different in the two functions, it is very strange.
Unread 02-02-2008, 21:39
FRC #1277
At first in the IR ifs, but when it was acting strange,I began to try it everyway I could think of, finally even with direct assignments, printing out the values to make sure, and it always acted like that. I cut and paste it into Default_Routine() and it was fine. I wonder if somehow I'm generating PWMs to often or something, but I don't see where.
Unread 02-02-2008, 21:46
AKA: A. King
Rookie Year: 2007
Oh, sorry I didn't notice before... Go look at the sticky topic about PWM 13-16 replacement code... Those ones are different from the rest, if you'll read. Or just change the PWMs to a lower value and see what happens. That's almost definitely the issue.
Unread 03-02-2008, 11:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The comments in the code seem to indicate that you're using the IR sensor board. That board doesn't provide a switch closure to ground. It provides a voltage output: 0 means the signal is not detected, and 1 means it is. If your digital inputs are coming from the IR board, you do have your tests backwards.
Unread 03-02-2008, 12:46
FRC #1277
Thanks. No, for troubleshooting I was using a jumper on the inputs, no IR reciever connected. That's why if digtal in ==0.
Problem with PWM outputs on RC Adam Richards Control System 1 20-02-2007 06:37
I have a BIG problem with my controller, need help. razer Control System 7 12-01-2007 06:21
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
need help with autonomous caderader Programming 3 14-02-2005 18:25
PWM problem in autonomous outofcontrol Programming 5 27-02-2004 11:58
