Calling functions from other documents
In MPLAB, how do I call functions from other files in a project?
Here is my code: Code:
static int counter; counter = Get_Encoder_3_Count(); Here is the function code: Code:
long Get_Encoder_3_Count(void)
long count;
INTCONbits.RBIE = 0;
count = Encoder_3_Count;
INTCONbits.RBIE = 1;
return(count);
Error - could not find definition of symbol 'Get_Encoder_3_Count' in file 'V:\frc-code-2007-8722\FrcCode_2007_8722\user_routines.o'. Last edited by Kilroy0846 : 03-02-2008 at 00:03. Reason: Added The Error Text |
Re: Calling functions from other documents
declare the function reference as external to your source file.
Code:
extern long Get_Encoder_3_Count(void); |
are you #include'ing?
I have the both the files encoder.c and encoder.h included. I added the external identifier, but I still get the same error.
Here is my new code: Code:
static int counter; extern long Get_Encoder_3_Count(void); counter = Get_Encoder_3_Count(); |
If you're using more than one function from a file, you could just include that file's header file. Use quotes if it's not a library that comes with the compiler.
#include "myfile.h" |
I Have the code:
#include "encoder.h" #include "encoder.c" located at the top of the document |
It sounds like you haven't set up the encoder stuff correctly. Not all the encoder code is enabled by default. If that's the case then that routine isn't being compiled - its being excluded because ENABLE_ENCODER_3 isn't defined.
There is an encoder_readme.txt file in the documentation directory and there is info in the encoder.h file. Is the ENABLE_ENCODER_3 line in .h un-commented? |
You don't need to include "encoder.c", and in fact, you probably shouldn't.
I don't think that's the problem, but if you include a .c file, you're probably going to get an error about something like multiple declarations of something. The headers tells the file that a function exists somewhere in one of the .c files. The actual code for that function doesn't need to be in the same .c file the function is used in. |
Take a few steps back. Undo everything you've tried to do in order to make it work. Read the documentation (I think it's called encoder_readme.txt) that comes with the encoder software. Follow the steps (nine of them, if I recall correctly) to add the code to your project and configure it.
If it still doesn't work, let us know. |
#10
| Calling C functions from EasyC | koenig3456 | Programming | 4 | 27-01-2006 16:03 |
| How Do I Program My RC To Spot One wheel From Going faster than the other | Kyle1010 | Programming | 5 | 12-01-2003 15:30 |
| Stack height Poll (spawn from other thread) | Andrew Rudolph | Chit-Chat | 5 | 07-01-2003 17:15 |
| Legality Issues Regarding Gears From other vendors | kilpatrick | Rules/Strategy | 1 | 17-02-2002 09:04 |
| And once more from the top... GLORIA! GEFORCE 3! AND OTHER CARDS... | Robby O | 3D Animation and Competition | 1 | 24-01-2002 20:12 |
