Go to Post Of course our robot can fly! - Bill_B [more]
Unread 03-02-2008, 17:20
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
pic: 1825s Chassis as of friday...
Unread 03-02-2008, 17:21
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: pic: 1825s Chassis as of friday...
really nice rack and pinion set up there.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 03-02-2008, 17:25
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Great use of protective bubble wrap!
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 03-02-2008, 17:28
Martino's Avatar
FRC #1825
thanks i didn't do a lot of work on it... but i am helping where i can...
Unread 04-02-2008, 09:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Excellent battery placement for weight distribution. The common wrong assumption is to put it over the rear inside traction wheel.
GitHub
Unread 04-02-2008, 12:27
Martino's Avatar
FRC #1825
yeah they went back and forth on where to put it... and they went with putting it there...
Unread 04-02-2008, 12:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think it looks great!
Do you have any ball manipulation plans that you can tell us about?
Unread 04-02-2008, 12:50
Martino's Avatar
FRC #1825
they were working on some sort of ball manipulation thing when i had to leave on Saturday(i had to go run sound for a concert) so they have something going... don't know what tho... sry
Unread 04-02-2008, 14:19
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I love the modified Ackerman Steering, do I see a slight angle coming off the pinion? Looks like you can turn to the left better than you can turn to the right, right? If you were to drive your steering off the tierod and you have the clearance, you could probably turn equally good in both directions. I am not sure you would need to, but it might be nice to have. We planned on writting software to speed up the outside rear wheel depending on how much the front wheels turned. So far that does not appear to be necessary. Have you programed anything to compensate for the rear wheels when turning?
EDIT: What kind of turning radius do you get? I am guessing that moving the wheels in a little helps you.
Unread 04-02-2008, 14:53
mattotters's Avatar
mattotters mattotters is offline
leadership/fab team
FRC #1228 (A-MERK-IN-INDIANS)
Team Role: Mechanical
mattotters is an unknown quantity at this point
Send a message via AIM to mattotters
Any binding in the wheels? and what are the widths of your front wheels? and what is your radius?
No sleep till the new jersey first robotics regional!
Unread 04-02-2008, 16:09
Martino's Avatar
FRC #1825
i think that we can turn better to the left but don't know...(its not programed yet) i think they will put something like that in the program like that... but i don't know... don't know the turning radius but i know it is tight...
no binding in the wheels that i know of... all of the the wheels are 2 IN wide... and don't know the radius... sry
pic: 1319 at Boilermaker Friday Morning Jherbie53 Extra Discussion 5 25-03-2006 17:12
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: Woodie's Speach Friday Morning petek Extra Discussion 6 23-04-2005 22:34
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
