resistors
I felt this should go in chit-chat because most FIRST robots don't deal with micro electronics,
a team member and me are doing a little side project while we build the robot that calls for a 20K resistor, sadly the only thing I have close to that is a a few 10K resistors, if I strung them together would it suffice? is there any method of combining resistors to combine their resistance? |
Re: resistors
Resistance adds in series. If you connect 2 10k resistors in series it is the same as 1 20k resistor.
Re: resistors
...so two 10k resistors can be combined to make 20k.
Re: resistors
Yes, 2 10K resistors in series, one after the other, is 20K
2 10K resistors in parallel, is 5K HTH |
| DIP/SIP resistors | John Gutmann | Electrical | 9 | 26-08-2005 20:27 |
| LED's, resistors, computers... ohm my! | DanL | Electrical | 3 | 01-07-2003 09:37 |
| Internal Fuses (PTC Resistors) on Window Motors | bigqueue | Technical Discussion | 6 | 08-02-2002 21:34 |
