Go to Post The only thing a team needs to survive is people who want it to survive. - Ryan Foley [more]
Unread 04-02-2008, 10:29
AmitCarmeli AmitCarmeli is offline
FRC #1943
AmitCarmeli is an unknown quantity at this point
Compiler Error
We have had some problems with the compiler, which kept informing:
"- section_entry_scn type is non-overlay or absolute but occurs in more than one input file".
To clearify, we have written one source file named "UserCommand", with the appropriate header, to handle, of course, the users' commands.
What have we done wrong?
Thanks in advanced, Team #1943.
Unread 04-02-2008, 11:04
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Compiler Error
That means you've inadvertently used the same .c file in your project twice.
Make sure you haven't accidentally "included" ANY .c files, e.g., "include ifi_startup.c" is incorrect. Only .h files are ever included.
Unread 04-02-2008, 12:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Compiler Error
The other possibility is that you've copied your code to another directory. Until you do a "Clean" (or a "Build"), something in the MPLAB project information is still pointing to the original files, and it picks up some of the same data twice.
The easiest way to fix this requires a single keystroke. Instead of just pressing F10 to compile, use Control-F10 to do a full build of the project. That will clear up anything still hanging on from the previous directory. Once that's done, F10 alone will be fine -- until the next time you copy your code to another directory.
Compiler Error Vanquish Programming 2 14-01-2008 16:36
compiler error SgtMillhouse648 Programming 5 05-02-2007 15:21
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
WEIRD compiler error Rickertsen2 Programming 7 05-02-2005 14:09
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
