Additional IR Sensors?
The robot will be unable to receive IR input after the robot has turned around the track because the sensor will be facing the oppostie direction. Have any teams considered having multiple IR receivers and then retransmitting back to the original sensor?
Is there a rule preventing repeating of IR codes for fear of interfering with other robots? If not, is there a rule about having multiple IR receivers or altering the supplied receiver? |
Re: Additional IR Sensors?
There is no rule that would prohibit what you describe.
The IR sensors actually has a 360 degree field of view. Our team tried it out (with a BetaMax remote :O) and we noticed that it could recieve a signal from any angle (if not obstructed of course). As long as you don't have anything to limit its FOV you should be fine.
| Additional Processors | chris31 | Programming | 12 | 22-09-2006 23:07 |
| where can we buy hall effect sensors or gear tooth sensors | amirjpl | Electrical | 3 | 13-02-2006 11:02 |
| Source for Additional Gear Tooth Sensors | Madison | Kit & Additional Hardware | 3 | 18-01-2006 16:57 |
| Additional Parts | ph@ntom | Robotics Education and Curriculum | 6 | 23-11-2004 23:52 |
| additional materials | Penn Robotics | Off-Season Events | 1 | 01-11-2001 23:25 |
