Go to Post Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom :P - Chris is me [more]
Unread 04-02-2008, 19:35
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
problems with cheap 10k ohm linear taper
We've been trying to use the 10k ohm linear taper for our steering mechanism keep burning out, we plug the 2 outer wires to the positive and negative on the pwm cables and also the middle wire to the middle wire, but for some reason we keep burning them out and also the values aren't what they're suppose to be, when i turn the taper half way and connect it the value of analog is 1000 and then when we turn it further to the right or left it starts to smell burnt. The thing is we had it working before, but then when we switched our robot back on it just burned out. If anyone can give any inputs on why it is happening or how to fix it, it'd be greatly appreciated thanks!
Problems with IR sensor xrabohrok Electrical 7 08-01-2008 23:15
Using cheap drill gearboxes with kit motors sanddrag Technical Discussion 3 03-04-2006 21:35
Are 100k Ohm pots necessary? MikeDubreuil Electrical 23 18-02-2005 09:30
LED's, resistors, computers... ohm my! DanL Electrical 3 01-07-2003 09:37
ksc - ball bots ohm my katie86 Regional Competitions 8 10-03-2002 22:52
