Go to Post The spirit of FIRST lives in all of them[us]. Knowledge is power and the unknown is scarey but in the end the spirit of FIRST will endure. - LSevcik [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-02-2008, 19:37
johnnysanchez johnnysanchez is offline
FRC #2582
johnnysanchez is an unknown quantity at this point
Electrical Component CAD models
"first timer need help in inventor i cant find the wires on firstbase"
wiring most of the wiring is not in firstbase were can i find it
but i cant find the victor or the spike on firstbase what is it under
Unread 04-02-2008, 20:02
CraigHickman
Posts: n/a
Re: Inventor
Usually one thread is enough to get an answer...
But anyway, if you mean the electronics, they're all there. Actual wiring is not provided, you need to make it yourself with the pipe/wire run feature. I personally never do it, but some teams do.
Unread 04-02-2008, 20:13
CraigHickman
Posts: n/a
Re: Inventor
Electronics kit. You can find it here.
Unread 04-02-2008, 20:14
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Inventor
http://www.firstcadlibrary.com/
Under Electrical on the left side, it is listed as motor controller and spike relay.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2008, 20:15
CraigHickman
Posts: n/a
Re: Inventor
Also a good resource. However, he was asking about the official KOP. I had forgotten about Firstcadlibrary. Mr. Spark's CAD is awesome.
Unread 04-02-2008, 20:39
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Inventor
Please post your questions only once and in the appropriate forums. I've merged the three+ threads you started about this into a single thread.
Also, please choose a title that is as descriptive as possible. Vague thread titles will make a lot of people ignore them entirely as they don't have time to read every single post. It makes it harder for others later to search the forums to find information they need and it all creates more work for me. I am lazy.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 06-02-2008, 21:29
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Re: Electrical Component CAD models
This is a general question. I am trying to wire our robot this year in Autodesk Inventor Professioinal 2008. Right now, all I can do is make a straight line that cuts through objects. Is there anyway to bend a wire without using a mount? To make it look like the path of our actual wire and tubing?
I've looked at other Chief Delphi posts and I've seen this on other robots but not explained. Maybe I'm wrong, please help!
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 17-11-2010, 09:14
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
To wire a robot in CAD can be extremely time consuming with a very low cost benefit analysis in my opinion. If you use the 2010 or 2011 Inventors there help files and tutorials are more straight forwards.
Basically to make wire you make a new "wire harness" then inside the wire harness you add wires between the points (connectors) you want the wire to be. Then you have to take the straight wire created and add points to curve the wire around to not pass through anything.
Doing this for your entire robot is extremely computer resource hungry and the easiest way to make Inventor crash/lockup.
Our CAD from 2010 can be seen on the Autodesk design showcase at
http://students.autodesk.com/?nd=sho...0&jid=1914 13
Unread 17-11-2010, 10:59
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Drakan290 made a excellent how to guide as to how to make wire here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=64206
Also if you are looking CAD models of parts you should also look at
cad.team1323.com
CAD Component drawings customh Electrical 0 20-01-2007 10:51
Electrical component measurements... Cody Carey Electrical 3 15-08-2006 11:05
Electrical Component Kit John Gutmann Electrical 9 30-08-2005 07:35
2004 Electrical Component Rule Rationale phrontist Electrical 31 06-01-2005 22:12
Looking for unusual electrical component JamesJones Electrical 11 08-07-2003 20:36
